Old 01-26-2014, 09:40 PM   #1
Kingjasn
Kingjasn's Avatar
another drum to disk conversion question
has anyone done a conversion, and taken the time to do a step by step with pictures?
Kingjasn is offline   Reply With Quote
Old 01-26-2014, 10:22 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: another drum to disk conversion question
Welcome to the forum. In the sticky threads area, just above the main threads, there is a 60-66 FAQ post that Woogeroo has taken a ton of time to put together. So many of the most commonly asked questions have links to threads that answer these reoccurring questions. It's worth taking a look at.
As for your question, this will put you into the right area in that FAQ regarding brakes conversions, http://www.67-72chevytrucks.com/vboa...60&postcount=3
Enjoy.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-26-2014, 11:48 PM   #3
earl84
I can't locate it right now, but i think it was hilandr, a member on here did a really good writeup on a C20. It's all the same process as a C10. Do a search for threads by him.
earl84 is offline   Reply With Quote
Old 01-27-2014, 09:55 PM   #4
Kingjasn
Kingjasn's Avatar
thanks for the replies guys... (huh huh, that rhymed) I did look in the FAQ section and found some really great write ups and step by steps, but pictures seem to help with avoiding rework. I am confident I can do it, so I think I will give it hell and take a bunch of pictures to post as I go through it. By the way, I am going to take the whole cross member from my donor 72 and slap it under the 65. Gonna start it on Saturday!
Old 01-27-2014, 10:16 PM   #5
T.W.Dustin
T.W.Dustin's Avatar
I am looking forward to seeing your pics as you progress. Good luck!
Please Watch for Motorcycles
T.W.Dustin is offline   Reply With Quote
Old 01-28-2014, 01:06 PM   #6
Branman1971
Branman1971's Avatar
I decided that I am gonna do the same before moving on to working on the cab. Then I can finish painting my frame and get it out of the shop to make more room. I have a couple questions though. So if I install a crossmember and suspension and disc brake components out of a 75 or so, what happens to my 61 original torsion bar suspension? Remove it completely? Also, my hubs and rims are 5 lug, which I think are original for 61 C10, but what are the lugs on the mid 70's trucks?
Active duty Navy CPO
1961 C10 SWB
1963 C10 LWB (donor)
1965 C10 LWB BBW
Branman1971 is offline   Reply With Quote
Old 01-28-2014, 01:30 PM   #7
jtrichard
61 c10 1/2 ton would be 6 lug c20 would be 8 if you have 5 lug some one has changed the hubs and rear
jtrichard is offline   Reply With Quote
Old 01-28-2014, 01:47 PM   #8
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
C-10. 5x5 lug pattern is from 72-98, some 1971's ... And Kingjasn if your 72 Doner truck have a Rear end, that's a Direct Bolt-in for a matching 5x5 lug for your truck...
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 01-28-2014, 01:52 PM   #9
Branman1971
Dang it...Thats what I was afraid of. I thought I was gonna be able to use my 5 lug rims after combing through this thread and seeing so many 5 lugs.
http://67-72chevytrucks.com/vboard/s...d.php?t=379110
That sucks
1961 C10 SWB
1965 C10 LWB BBW
Old 02-13-2014, 04:46 PM   #10
Branman1971
I actually went with a 83 C10 that I found on CL. For $160 I am getting the crossmember and all components, master cyclinder, brake booster, proportioning valve, power steering components, and for another $50 I can take the steering column with tilt but I probably wont. Again, there's an issue with the lugs on the donor, there are 5 lugs and my rims are 6, but I saw where someone swapped rotors from another year that fit the spindles. Cant find it now though.
1961 C10 SWB
1965 C10 LWB BBW
Old 02-14-2014, 01:21 AM   #11
Captainfab
60-66 Nut
The only 6 lug rotors that are going to fit those spindles are the aftermarket rotors. That is providing that '83 has the HD spindles with the 1.25" thick rotors.
Old 02-18-2014, 02:25 PM   #12
Branman1971
Thanks CaptFab. I thought I could use a rotor off of a C20 but I cannot find where I saw that info. Guess it was wrong anyways. I believe the rotors on my donor started out as 1.25" and have been turned cause they measure just a hair over 1.00" now. I am going to make sure tonight that they are the HD rotors so I can swap them with the aftermarket 6 Lug rotors that fit my rims. I was confused in earlier posts, my rims are 6 lug and I was calling them 5 lug. Duh!
If, and I pray it's not the case, but if this front end is NOT the HD setup with 1.25" rotors, what are my options? Can I bolt up some HD spindles and go from there?
1961 C10 SWB
1965 C10 LWB BBW
Old 02-18-2014, 04:18 PM   #13
Branman1971
Update: NAPA shows to have rotors for this truck and there are 2 different heights but both are the same 1.25" thickness.
1961 C10 SWB
1965 C10 LWB BBW
Old 02-18-2014, 04:50 PM   #14
kieth
kieth's Avatar
Even if you found 6 lug hubs for the front your stock wheels would not fit over the disc brake rotors and caliper.......might as well get ready to go 5 x 5....with some newer steel wheels .....Kieth (or go 6 lug rallyes but they are getting harder to find...)
I converted mine to 5 x 5 and went with custom wheels....
http://kieth.smugmug.com/Trucks/66-GMC/i-wLm4dMM
kieth is offline   Reply With Quote
Old 02-18-2014, 06:41 PM   #15
Branman1971
I don't have stock rims, but these might not fit either.
So if I go with 5x5 how do I get my rear switched from 6 to 5 lugs?
1961 C10 SWB
1965 C10 LWB BBW
Old 02-19-2014, 02:17 PM   #16
Branman1971
Nevermind, im gonna keep my 6 lug setup and get a 6 lug rotor from somewhere. I just need to make sure the old 5 lug rotors were originally 1 1/4" width. They are about 1" now and someone told me that they were probably 1 1/4' when new but have been turned. There are numbers on the old rotors that read 14008847, L-103, K2, MINTHICK, and 24-5. Can anyone tell me if they were 1 1/4" when new by these numbers? If not, i gotta buy new spindles too.
1961 C10 SWB
1965 C10 LWB BBW
Old 02-19-2014, 02:26 PM   #17
gofastnut
gofastnut's Avatar
Branman,
Minimum thickness is 24.5mm, which is just under 1", .096 something.
Can't find or X-reference the 14008847 number. Sorry I couldn't be more help.
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 02-19-2014, 03:01 PM   #18
Branman1971
That helps gofastnut, i think i got it figuered out now. The 1" rotors have an overall height of 4.640" and the 1 1/4" rotors are 4.95" height, so when I get home I will measure their height and see where they are. Also, the 1" rotors new show a minthick of 0.965 per Oreilly's website, so it looks like i got the wrong ones. Guess I will be back at the junk yard for spindles. I know where some 1971 spindles are for free I believe, and they are beefy.
1961 C10 SWB
1965 C10 LWB BBW
Old 02-21-2014, 12:46 PM   #19
Branman1971
Is it true that I can use spindles off of a suburban as well? Does anyone have any details?
1961 C10 SWB
1965 C10 LWB BBW
Old 02-21-2014, 01:30 PM   #20
siggyfreud
siggyfreud's Avatar
I believe Suburban spindles work as well up to 91. I think 73 is the earliest year that will work, as 67-72 had a different setup, but I could be wrong . Still muddling through this all myself.
siggyfreud is offline   Reply With Quote
Old 02-21-2014, 01:37 PM   #21
Branman1971
Will it take same ball
Joints? I guess that's my concern.
1961 C10 SWB
1965 C10 LWB BBW
Old 02-21-2014, 02:50 PM   #22
gofastnut
gofastnut's Avatar
OK, I'm going off memory here, so use at your own risk. 73-87 1/2 ton 2WD truck and ?? to 90 or 91 1/2 ton Van and Burb(again, 2WD) should work on our 60-66's.
I thought it'd be easy to find a mid 80's 1/2 ton van for all my parts--not so lucky!
Jeff
C-10 Club
Old 02-21-2014, 04:08 PM   #23
Branman1971
I found another donor and it has the 1 1/4 rotors so I'm pulling the spindles. Do I need the calipers too or will the 1" rotor calipers work?
1961 C10 SWB
1965 C10 LWB BBW
Old 02-21-2014, 04:16 PM   #24
siggyfreud
siggyfreud's Avatar
Not sure on the calipers. Look up replacement part numbers on auto zone or O'Reilly's and see if they're different.
Old 02-21-2014, 05:40 PM   #25
Branman1971
Good idea. It worked!!!
1961 C10 SWB
1965 C10 LWB BBW
