Old 02-18-2014, 08:09 PM   #676
sduckworth13
sduckworth13's Avatar
Re: Crusty Rusty Leaky Squeaky 67 Step
Cab is looking great Vic. You make it look easy to replace the whole floor.
Scott
sduckworth13 is offline   Reply With Quote
Old 02-18-2014, 08:40 PM   #677
Vic1947
Vic1947's Avatar
Thanks, Scott. I reckon you've been putting in some hours at work with the few decent days we've had this week.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 02-18-2014, 09:07 PM   #678
sduckworth13
I haven't been working much the last two weeks, I did get to work today for 4 hours today though. I did get a chance yesterday to weld up most of the holes in the firewall I'm not going to use. I'm not real sure what other misc holes to weld up on the drivers side. The more holes I fill the more expensive it'll get, so I'm trying not to get to fancy. Showed Roy the patch you made me, he was very impressed with your work.
Scott
Old 02-19-2014, 09:27 AM   #679
Low Elco
I'm interested in this metal slitting blade. Good stuff to follow, fellas!
Low Elco is offline   Reply With Quote
Old 02-19-2014, 08:27 PM   #680
Vic1947
Vic1947's Avatar
Finished removing the stake pocket tin and welded patches in two of the three holes on the passenger bedside. The one at the rear didn't require a patch because I have a shortbed panel that replaces everything from the middle of the wheel well around to the back corner where the tail lights install. It has no provision in it for the stake pocket. After watching John Sanborn's bed mods, I liked the idea of using heavier material for the patch, so I used 1/8" plate instead of 16ga. Taped off the cut lines inside and out, then got busy removing the driver side panel from the floor. Hopefully, the metal slitting blade I ordered will get here tomorrow or Friday. I plan to use it on the floor to make a more precise cut than I could make with cutoff wheels. I figure if I get the floor dead nuts, it will make it easier to line up the rest.
Victor
Old 02-19-2014, 08:40 PM   #681
jeh
jeh's Avatar
Looks good Vic. No doubt it will turn out nice after watching the quality work you do.
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 02-20-2014, 10:37 AM   #682
Xeen
Xeen's Avatar
Oh heck yeah this is the part I have been looking forward to.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 02-20-2014, 01:19 PM   #683
mcbassin
Still Learning
mcbassin's Avatar
I'm really looking forward to watching this bedside modification..I have shop envy too. Your shop looks too clean and organized.
Old 02-20-2014, 02:06 PM   #684
Low Elco
That's not the word for it, Mike. Keep in mind it's in the basement of the house. You could be a damn rocket engineer, Vic makes you feel like a dirty slacker. Wrapped in the nicest guy you could hope to meet. Ask him about the '57 Ford sometime!
FYI, this bed is solid, but it's HASHED. It'll be a neat trick to pull this off. Over here eating popcorn....
Old 02-20-2014, 03:42 PM   #685
Xeen
Xeen's Avatar
As you say the bed is solid and he has a replacement bedside "half" so the rear section that has all the damage on it is being completely replaced which greatly simplifies things and reduces the amount of overall work he has to do to restore it.
In comparasin to the other repairs he has done on his cab this is the easy part, where as the cab took months the bed will take a week. It's all precision work there is just much less of it to do on the bed.
Old 02-20-2014, 03:55 PM   #686
Low Elco
I'm aware of all the above. I was simply saying we're all in for a treat, as free hanging panels are a bit of a challenge to keep in line, although easily within Vic's skill set. I for one will enjoy the opportunity to enhance my skills through Vic's experience, as I've done several times both in this thread and in person.
Old 02-20-2014, 06:11 PM   #687
jlsanborn
jlsanborn's Avatar
Your approach on the stake pockets is what I should have done
Live and learn
Once I cut through the bed rail I lost the straight line and it was a bugger to weld up without it pulling around.
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 02-20-2014, 07:28 PM   #688
Vic1947
Vic1947's Avatar
Thanks for the vote of confidence, smellers, but after today I ain't so sure it's justified. You know how something seems so perfect on paper, then reality sets in? My experiment with the metal slitting blade might have worked had I chosen more wisely ...hard to say. The blade arrived at lunchtime, so this morning I went ahead and sectioned the passenger bedside using a 6" x .040" cutoff wheel. The larger diameter keeps the cut pretty straight. I set the three pieces I'll need aside and put the driver bedside up on the stands to prep it.
With the metal slitting blade in hand, I set up to section the floor. I've had this EZ Guide tool for a number of years and it works great on wood. I bought it for the rare occasions when someone holds a gun to my head and forces me into carpentry work. The tool allows a loner like me to make cuts that would normally require a couple of persons. Plus it pretty well eliminates the need for a table saw. Anyway, I figured with the appropriate blade, I could setup the guide and make very precise cuts to the floor. Might have worked if I had a more powerful saw or a better or different style blade. Regardless, I spent way too much time wearing my way thru the material, stopping often to cool off everything and mumble swear words.
So I abandoned my big plan and whipped out the same thin kerf cutoff wheel I used on the bedside and made short work of the remaining cuts on the rear section.
Victor
Old 02-20-2014, 07:42 PM   #689
Vic1947
Vic1947's Avatar
Using the cutoff saw manually is, by definition, less accurate than a guided tool. Even if the line is fairly straight, leaning the blade one way or another can create misalignments when you fit it all together. The good news is that I left enough material to be able to sand it to fit. I'll do that tomorrow, then fixture the rear floor section and start tacking it together. And it's on to the front section next.
Victor
Old 02-21-2014, 09:27 AM   #690
Low Elco
I like that guide thingie-gotta get one o' them. Sorry your blade didn't work out.
Old 02-21-2014, 10:21 AM   #691
mcbassin
Still Learning
mcbassin's Avatar
Sorry to read about the metal blade not working out. I have seen those used for metal building panels. I personally like the abrasive blades. They wear out fast when you're doing that much cutting though.
I like to scribe a line with Dykem layout fluid then grind to it. Sounds like you are off and running on the bed shortening chore.
Keep up the good work.
Old 02-21-2014, 08:06 PM   #692
Vic1947
Vic1947's Avatar
Me too, Mike. Should have laid out the lines first, but it worked out anyway. I had some errand running to do this morning, so not as much done as I'd like. Scott Duckworth came over this afternoon and brought me a 6 lug rally wheel to use for my spare tire. We had a good visit and he helped me trim the panel I plan to use on the hood and we did some MiG welding also. The rear of the floor is looking pretty good. Should get it welded out and ground tomorrow, then on to the front ...better late than never.
Victor
Old 02-21-2014, 09:25 PM   #693
sduckworth13
That was fun Vic, thanks for giving me the grand tour of the shop.
Scott
Old 02-21-2014, 10:37 PM   #694
jlsanborn
jlsanborn's Avatar
Nice work on the floor section! I can see where you were headed with the Skill Saw. I put a metal roof on my Pa's house years back and tried the "backwards wood blade" and straight-edge technique. OMG they don't make ear plugs, muffs, glasses or sleeves that are built for that kind of torture. I always thought that if they made the right blade (vs. abrasive) that'd be the trick. Minimal heat and clean, straight cut.
I spy some stuff in your last photo.... New helmet and gloves - need the story... why no Speed Glas? Did you buy that COOL copper backer with the handle on it? I've got a couple flat bars but I mostly use this big-old Tweako welding cable ring terminal, which SUCKS cuz it's got a big-ass hole in the middle!
Old 02-21-2014, 11:02 PM   #695
Vic1947
Vic1947's Avatar
Anytime, Scott, thanks again for the wheel!
Victor
Old 02-21-2014, 11:05 PM   #696
swamp rat
swamp rat's Avatar
Looks great! I hope to do this some day if i never find a short bed, reading with high interest.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-21-2014, 11:13 PM   #697
Vic1947
Vic1947's Avatar
Thanks, John. I've been lurking on eBay ever since my Speedglas gave up. So far nothing in my price range. I'm watching several items, so we'll see. Meanwhile, my old helmet was not auto darkening, so I picked up the one in the photo from HF to get me by while I wait on a "deal". Copper welding spoon is also an eBay item, $16.90 + free shipping. Previously, I used a piece of copper tubing that I split and flattened out. I keep it around because it can be formed to get into corners and tight spots.
Victor
Old 02-21-2014, 11:23 PM   #698
Vic1947
Vic1947's Avatar
Thanks. I've read several threads where this has been done. No two seem to be the same. I'm still not sure what to expect when it comes time to join the sections together. I hope to post detailed pictures of the seams and what it takes to make them align.
Victor
Old 02-21-2014, 11:29 PM   #699
swamp rat
swamp rat's Avatar
That would be great..
BTW: check out Amazon for helmets too, ya never know.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 02-21-2014, 11:29 PM   #700
jlsanborn
jlsanborn's Avatar
Whah? Speedglas gave up???? To me it's the Snap-On of glasses. Last time I was in the supply store there was tons of stuff but never really looked cuz mine works perfect. I've even been paying $$$ for Speedglas lenses...
