Old 02-18-2014, 12:55 PM   #1
frankdatank01
Putting it back together...What step and when?
All,
This is my first rebuild and it's been a looooong (5 years) project with family, kids, etc.
I've got the engine/trans installed, brakes/lines installed, fuel lines installed, front parts installed. I still need to install the new wiring harness on the engine bay side. I'm killing my brain trying to figure all the little steps to get this back together.
But I think I'm ready to reinstall the front clip...from the photo below, what do you think? Should I wait to install windshield before or after the front clip? Is there anything else I need to hit before putting the front back on?
I'm just trying to take advantage of everything possible while the clip is off. It has been really helpful with all the open workspace.
Frank
frankdatank01 is offline   Reply With Quote
Old 02-18-2014, 02:00 PM   #2
Lee H
Lee H's Avatar
Re: Putting it back together...What step and when?
Looks like your making good progress. I would have the windshield installed before the clip. Then the heater/AC, at least on the firewall side, then the wire harness at the firewall, at least roughed in, trans cooling lines, then the clip, then the balance of the harness.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-18-2014, 02:54 PM   #3
frankdatank01
Thanks! I almost forgot about the trans lines :-) I'm going to hold off on heater/AC for now as that's going to be a new upgrade down the line.
Just ready to get it wired, fired, and on the road in fair weather :-)
Old 02-18-2014, 09:06 PM   #4
Daman
You can do the core support and radiator to get that all set up but I'd keep the fenders off until the end.
The reason behind that is you will be rubbing and bumping into them a lot with what's left
Daman is offline   Reply With Quote
Old 02-18-2014, 09:28 PM   #5
54blackhornet
54blackhornet's Avatar
Make sure you get that heater assembly on firewall installed for sure, real pita to do with inner fender and hood on ! Looks like you have done a great job so far, engine loos beautifully....
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
