Re: question about grinding/roar noise
It sounds as if the trans may have a bad output shaft bearing,or input shaft bearing.
I would drain the trans,and check for metal in the pan/filter.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect ! I'm busier than a one-legged cat,in a sandbox! Veteran..and proud ! I can't fix what ain't broke....you want I should break it? |
| Bookmarks |
| Tags |
| c20, grinding |
