Old 10-20-2010, 02:44 PM   #26
coryalexander
Re: what vehicles came with 200r4 from junk yard
Originally Posted by coryalexander View Post
ok , i stand corrected, the tranny in the camaros was a th200c
but all v-8 f-bodies did not come with a 700r4 my 82 came with the 200 and my brothers 82 Z28 came with the 200 you could replace them using the same DS and mount with a t350 you just had to buy the tourqe arm adapter
coryalexander is offline   Reply With Quote
Old 10-20-2010, 06:34 PM   #27
stich626
that is not correct, on the earlier year camaro`s it had a 3 speed shifter it only had D-2-1 they where the 200 in them . the camaro`s with this shifter in them was the 200 , the f-body`s from 82 up did not come from the factory with a 3 speed tranny , the od kicked in on its own.
that od kicking in was the lock up converter
stich626 is offline   Reply With Quote
Old 10-20-2010, 06:38 PM   #28
stich626
we are talking overdrive tranny's
the 200c is a 3 speed no overdrive. only lock up converter clutch..
no f body came with a 200r4 all where 700r4
some 78-81 had th250 three speeds..
the thread was about overdrives so I didn't think I needed to include the 3 speed 1 to 1 high gear automatics
Old 10-20-2010, 07:25 PM   #29
packers05
I have had a few 2004r behind strong engines one 87 buick gn that I would guess around 375hp 12.70 at 118 [lots of tire spin] I had a manual lockup switch that turned it into feelng like a stick shift It locked the tqconv. at the 1-2 shift and stayed in under full throttle, it was an art carr convertor that could take it man I miss that car. I think they are better than a 700 any day
packers05 is offline   Reply With Quote
Old 12-18-2010, 01:04 PM   #30
KEL
72 GMC
KEL's Avatar
is there anything on the SPID or do i have to crawl under the vehicle ?
KEL is offline   Reply With Quote
Old 08-16-2013, 07:46 PM   #31
Ronald29609
I have a 67 chevy shortbox with an 80s 350 and 3 speed manual. Would the 200-4r be a good/easy swap?
Ronald29609 is offline   Reply With Quote
Old 08-16-2013, 08:59 PM   #32
POPO1984
POPO1984's Avatar
Should bolt right in place you might have to move the transmission crossmember but the drive shaft will bolt right in.
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 08-17-2013, 12:05 AM   #33
danno76
beeing a g body guru !!lo the used 200 trans in a lot of 79-87 cutlass,grand prix,monte carlo,and buick regals ,as well as 82-85 camaros and firebirds .most were bop which means buick olds pont and chev bolt patterns they were a very universal trans!!
danno76 is offline   Reply With Quote
Old 08-17-2013, 07:23 AM   #34
Ronald29609
Thanks for your help guys. I'm retired and not familiar with the new technology.
Old 08-17-2013, 09:06 AM   #35
terry b
terry b's Avatar
Will they bolt up to a 72-402?
terry b is offline   Reply With Quote
Old 08-17-2013, 01:15 PM   #36
Heavy Evy
born to lose
Heavy Evy's Avatar
I've always heard bad things about the 2004r but this post shed some good light on the subject
_____________________
'67 Chevy Belair Wagon 283 Powerglide
'68 Chevy II Nova 2 door 350 TH400 Sold!!
'71 Chevy C20 350 TH350
'71 Chevy C10 Burb 350 TH350 stolen totalled gone....
Burb Build
http://67-72chevytrucks.com/vboard/s...d.php?t=475155
Nova Build
http://67-72chevytrucks.com/vboard/s...d.php?t=498979
Wagon Build
http://67-72chevytrucks.com/vboard/s...d.php?t=543052
Not giving a truck.
Heavy Evy is offline   Reply With Quote
Old 10-13-2013, 03:18 AM   #37
overtimeracing
overtimeracing's Avatar
Hey guys...Whats the best way to identify the 2004r? Pan bolts, or is there an ID tag somewhere?
Why...Why...Why...Can't I leave anything alone???
overtimeracing is offline   Reply With Quote
Old 10-13-2013, 06:04 AM   #38
Pop's C-10
Pop's C-10's Avatar
Here's a handy guide
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 10-13-2013, 10:52 AM   #39
overtimeracing
Thanks Pop's C-10 thats sweet!
Old 10-13-2013, 11:37 AM   #40
LockDoc
The Older Generation
LockDoc's Avatar
The easiest way I have found is that the 2004r doesn't have a removable tailstock like the 700r4 or the TH350, the case is cast in one piece. (see pictures)
Here is an article about the 2004r that was in Hemmings Motor News that I will add to this thread.
http://www.hemmings.com/hmn/stories/...feature26.html
LockDoc
Leon
Old 10-13-2013, 12:33 PM   #41
Bigdav160
Bigdav160's Avatar
Be aware the lowly TH200 and TH200C are also one piece cases.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-15-2014, 07:22 PM   #42
TexasT
TexasT's Avatar
MX0 on the spid label for the 2004r
But a crawl under wouldn't hurt. No telling what might have been swapped in.
Rich
TexasT is offline   Reply With Quote
Old 02-15-2014, 07:43 PM   #43
For those nit picking on people saying 200r4 (which seems natural since GM put the letter after the first three numbers on 700r4) saying it's 2004r,you are also wrong. GM calls them 200-4r. Just a little side note on this four year old thread.
Old 02-15-2014, 09:10 PM   #44
TexasT
TexasT's Avatar
Call it what you want, I'm on my phone so a hyphen poses a extra keystroke or two so it gets dropped. People may or may not understand.
I do know the inner workings and why a 2004r does or doesnt work. And see there, I missed an apostrophy and a hyphen as that takes more keystrokes, too.
Rich
Old 02-15-2014, 11:31 PM   #45
I don't think those people I was referring to were posting from their phones in 2010. That's funny,extra keystroke. Don't wear yourself out for the sake of grammar
Old 02-16-2014, 02:46 PM   #46
Fitz
Originally Posted by 71meangreenc10 View Post
Deep inside this site someone is twitching about seeing 200r4 and having a major seizure Who will make the correction......LOL
Smitty
What's a misplaced letter or two amongst friends? We knew what he meant and not all of us are that anal retentive.
Fitz is offline   Reply With Quote
Old 02-17-2014, 11:02 PM   #47
Fleetline Fever
Fleetline Fever's Avatar
I installed a 2004r in my 69 CST short bed. The best part is, it was a powerglide truck to start with and the two trannys are the same length. All I had to do was move the cross member back to the already pre-drilled holes in the frame for the TH400. The drive shaft didn't need to be shortened and popped right back in. There is more to it than that, you do need to wire a way to unlock the torque converter & you need a bracket to attach the the TV cable to the carb (this is especially important to get correcct) I went the easy but pricey route of Purchasing everything from Bowtie Overdrives http://www.bowtieoverdrives.com/. They have everything included a wealth of information on their website and you can call their tech guys if you have questions. I bought a wiring kit from them that hooked up a switch to my brake light switch to unlock the torque converter when you hit the brakes. I also bought a TV cable setup made for a Edelbrock carb/manifold. Then don''t forget if you want your speedo to work properly you need to change out the speedo gears in the tranny. Now with a tonneau on the bed I get 19 MPG on the highway diving 70 MPH while the engine is turning just under 2000 RMP.
Fleetline Fever is offline   Reply With Quote
Old 02-18-2014, 04:30 PM   #48
camaney
I was using my phone at the time...time goes fast, it seems it was last year when I started this post
camaney is offline   Reply With Quote
Old 02-19-2014, 11:17 AM   #49
It's all good. I was just giving the nit pickers a taste of their own medicine. Nothing was directed at you or that other feller who felt he needed to defend himself.
