Old 02-19-2014, 03:47 PM   #1
the_goat_man
64 big block motor mounts
Ok so I have a 64 I am putting a big block in. I have to use tall valve that I have to use because of valve train what motor mounts will work or do I have to just cut the fire wall. It's is a 64 swb 1/2 ton step thanks
the_goat_man is offline   Reply With Quote
Old 02-19-2014, 08:24 PM   #2
60-66
60-66's Avatar
Re: 64 big block motor mounts
Hers what I did on a 1965 GMC short bed. I used the 1968-1970 style truck BB frame mounts that move the engine forward. Im not a fan of denting or cutting firewalls. These cleared by about a half inch.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 02-19-2014, 08:25 PM   #3
1963c-10
1963c-10's Avatar
60-66....guessing short water pump on that one?
1964 Short bed trailer
Old 02-19-2014, 08:40 PM   #4
gofastnut
gofastnut's Avatar
Man 60-66, that's a purdy truck! Looks super sharp!
Goat man, I've also got a big block to go into my 64. I'm a big fan of moving the engine as far down and back as possible(don't know how much that will be with a big block), so, I'll wind up cutting the firewall. But done right, they look good! There are a couple of posts on here showing big blocks in our trucks; some have been done really nicely, others for functionality.
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 02-19-2014, 08:44 PM   #5
60-66
60-66's Avatar
Yes Sir. Pretty much same as a 68-71 BB Truck as far as brackets and pulleys for short pump. Truck ran cool enough without a shroud as the fan was close enough to the radiator and I had it upgraded to a 4 core. I sure miss that truck,
