I recently, as in yesterday, upgraded all exterior lights to LED except the reverse light that did not work anyways. I have a couple issues.
First, the instrument panel lights stopped working. Checked all the fuses and they are GTG. The left and right turn signals work though. The exterior lights work for the most part which leads to Second the Side marker lights work, now, as a blinker also. The issue is they are also working as a brake light. The left side marker will work correctly if I turn the right signal indicator on. This same thing does not effect the right side. any help with this would be appreciated. thank you. |
![]() Join Date: Apr 2005
Re: LED Upgrade issue
Did you install and LED Flasher?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Cluster King
![]() Join Date: Nov 2012
Not sure if it is your issue but the LED's I use in the gauge clusters have a directional current flow. If they are in the bulb socket backwards, they will not light up. You have to flip them in the socket or flip the socket in the printed circuit board.
I am not sure if all LED's are like this but I have had this problem with the ones I have used before. Let us know what you figure out. Also, did you buy dimmable dash LED's? Who did you buy them from? Gppd luck, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
I did replace the turn signal flasher but not the hazard light flasher.
I used the LEDs from Classic parts of America. The below items are what was installed. I still original equipment lights in the dash 1971-72 Parklamp Lens-Chevrolet-Amber-LED Item :47-146 Price : $36.95 1967-72 LED Taillamp Lens - Fleetside / Blazer - Reproduction Red Item :49-236LR Price : $29.95 1968-72 Side Marker Lamp Assembly-Front Deluxe-LED Item :51-502LA Price : $29.95 1960-87 LED Flasher - 2 Prong-W/Polarity Reversing Adapter 60-87 Truck, 67-73 Camaro, 68-74 Nova, 68-72 Chevelle Item :53-566 Price : $10.95 1968-72 Side Marker Lamp Assembly-Rear Deluxe-LED Item :51-504LR Price : $29.95 Last edited by mbradsher; 02-19-2014 at 11:03 PM. |
