Old 02-20-2014, 10:36 AM   #26
79 silverado
Re: JEGS Ebay Crate Motor Deal Heads-up
With an 86 here is what you are facing if I recall correctly, and take all of this with a grain of salt you should verify:
* I do not believe you get the full benefit of the 3yr/100k warranty putting it in a 1986. That level warranty only goes for the "direct fit" applications, ie cars and trucks that originally came with a 350 engine of the model years listed. I think if you stick it in anything else you get 12 months/12k miles, but I may be wrong on that (see warranty)
* The 1986 was the oddball year of engine. It has the top-end of the 85 down motors, but, it has the block/crank/flywheel with one piece rear main seal of the 1987-up engines.
I cannot guess at the smog laws where you are located, someone local to you may need to chime in on that or talk to someone at a testing shop would be my first guess... but if you are asking, can you buy the engine, rest it on the motor mounts and have everything bolt up from the wiring/fuel/transmission/mounts direction then the answer should be yes, BUT, you will need to replace the flywheel/etc due to the one piece rear main seal - your existing one is different.
Intake and carb? shouldn't be a problem and would bolt on.
79 silverado is offline   Reply With Quote
