#26 |
Re: Installed airbags and still dont set low enough.
Possibly. Just make sure you aren't rubbing the bag on anything once you do.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#27 |
I run drop spindles with plates on top and cut cups on bottom(flush with lower arm) 245/45/17 tire 25.7 diameter. cross member hits the floor when aired out. yes cutting the cups will help.
#28 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Just don't cut the cup too much.
It needs to set solid in the lower a-arm I've heard 1-5/8" is the minimum total height. Any less and it will rock around in the a-arm.
#29 |
OK did find out that my ball joints are binding. What can I do about that? I noticed that when raising it from aired out to full up when it first starts going up I hear a clunk on both sides. I am going to cut my cups to 1 5/8" and should I weld them in or just let em set in the frame?
#30 |
I'm looking at pie cutting the uppers. Read a lot about the upper ball joints binding up n seems like it might be the answer. Anyone ever do it?
#31 |
![]() Join Date: Nov 2009
i don't have any cups on my a arms, just plates top & bottom; bump stop perch gone... dropped spindles.
just put the 17" vette wheels on the front and 18" on back. i have no issues with fender/ inner fender clearance and have full steering travel even when aired out. good luck putting her on the ground, my lowest point aired out is my lower a arms. WAGZ
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally used up and worn out, shouting '...man, what a ride!' GC |
#32 | |
If you ain't living life on the Edge.... Your taking up entirely to much space!!!! ![]() My 64 Stepper Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586792 |
