Old 02-16-2014, 11:22 PM   #1
Donaldo
Door jamb switches
What has worked best for dome light/jamb switches and lighting delays in the AD trucks ? I've reshaped a '99 surburban dome light fixture to fit the stock 51 location, and fit the '99s inside door marker lights into the lower door faces.
thanks, Don
Donaldo is offline   Reply With Quote
Old 02-17-2014, 06:57 AM   #2
S10Fan
Old Heap Driver
Re: Door jamb switches
These are fine..........
http://www.ebay.com/itm/Door-Jamb-Sw...ffe8cd&vxp=mtr
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 02-17-2014, 12:44 PM   #3
Donaldo
Thanks Bryan
Old 02-17-2014, 12:52 PM   #4
OrrieG
OrrieG's Avatar
I used these:
http://www.ebay.com/itm/2-DEI-8607-P...#ht_158wt_1105
Old 02-17-2014, 12:59 PM   #5
Donaldo
OrrieG;6530168]I used these:
http://www.ebay.com/itm/2-DEI-8607-Pin-Switches-
thanks, just ordered some -
any ideas on a lighting delay ?
Don
Old 02-17-2014, 02:47 PM   #6
Russell Ashley
Russell Ashley's Avatar
I used these. I chose them because they require only about 1/8th inch of clearance between the door and jam. Also, these are double pole switches which I needed for the courtesy lights I used.
Russell Ashley is offline   Reply With Quote
Old 02-18-2014, 08:01 PM   #7
Daze57
Daze57's Avatar
^ Them thar is what i am a using also ! work out real well
Daze57 is offline   Reply With Quote
Old 02-18-2014, 09:04 PM   #8
OrrieG
OrrieG's Avatar
Don
Delay or Relay? I used a bosch type relay with the ground as the activator to each door switch so that opening either door turns on the courtesy lights. Can't remember if I included a switch to disable when I do not want them to come on, may have to add that. The dome runs off the stock light switch.
Old 02-18-2014, 09:43 PM   #9
57chevyman
57chevyman's Avatar
I used Dorman 85932 self grounding door jamb switches
theyre available at Pep Boys and many other auto parts stores
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 02-18-2014, 10:02 PM   #10
Donaldo
""Delay or Relay?""
I want to use a delay, keep the courtesy interior lights on a little while after the doors close - at wifeys request.....since she 'bought' the truck !@!
Old 02-18-2014, 10:39 PM   #11
57chevyman
57chevyman's Avatar
http://www.revolutionelectronics.com/Dome_Light.html
its less expensive on ebay
http://www.ebay.com/itm/GM-Chevy-Mop...4ade1e&vxp=mtr
Frank
1957 Chevy 3100
Old 02-19-2014, 01:25 PM   #12
OrrieG
OrrieG's Avatar
Surprised that for $60 you only get 2.5 seconds delay and no adjustment? Better be fast finding the belts and key hole....
Old 02-19-2014, 02:44 PM   #13
57chevyman
57chevyman's Avatar
I just did a quick search...not sure what else is out there...would be better for dome light to fade off when ignition key is turned on.
I put a toggle switch in my dashboard so I ( or my passenger ), can easily turn on the dome light while the doors are closed. I probably could have used a black knob switch to match the wiper knob, but the toggle switch looks custom, like it might control something more exciting than the dome light LOL
Frank
1957 Chevy 3100
Old 02-19-2014, 03:04 PM   #14
mr48chev
mr48chev's Avatar
Which design of switch you use also depends on if you need to ground the circuit when the door is opened Which is what the switches that Brian, 57Chevyman and Russel showed or if you need to complete a hot circuit with the one that Orrie showed.
Most every older rig I worked on had the dome light switches going to ground. There was a hot wire running to the light and then a ground wire ran from the light to both doors so the circuit grounded when you opened the door or grounded when you used the switch on the light.
If you wanted to run a hot wire to the pushbutton switch on the door and then run a wire to the light and then ground the light you would use a two pole in and out switch.
My ongoing truck projects:
Old 02-19-2014, 08:41 PM   #15
chev3600
chev3600's Avatar
Donaldo, check out the DEI 528T. It's an adjustable timer relay that sounds perfect for your application.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 02-20-2014, 09:37 AM   #16
Russell Ashley
The NAPA switches in my post are double pole switches. The contacts close when the door opens. The hot wire goes to one side of the switch and the other side goes to the courtesy light which is grounded through it's housing. They use push in bullet connectors.
Old 02-20-2014, 08:23 PM   #17
OrrieG
OrrieG's Avatar
And only $15... here is how it works, 0-90 second delay.
http://www.remotestartexperts.com/dei-528t.html
Old 02-21-2014, 12:33 AM   #18
Donaldo
""Donaldo, check out the DEI 528T. It's an adjustable timer relay that sounds perfect for your application.
http://www.remotestartexperts.com/dei-528t.html""
I had looked thru all the ads I found and guess I missed that one - I did find one made in Oz for about $16US delivered, and it's is adjustable 5 to 60 seconds. So we'll see if it's any good....
My '51 has a bulb location in the ignition switch mount, so I will use the delay for that and small courtesy lamps over the kick panels, the dome light can go off when the doors close.
thanks for the help !
Don
Old 02-21-2014, 06:55 AM   #19
S10Fan
Old Heap Driver
The DEI528T is a good reliable piece, I've used a few of them in various applications over the years.
Bryan
