Old 02-20-2014, 12:26 PM   #1
aotte1
1973 to 78 Stepside Fenders fit 1986?
Will Stepside fenders from 1973 to 1978, fit a 1986 Stepside truck. Bolt to bed? Bolt to step?, basic shape the same? Would weld in left side gas door and weld up right door along with marker lights.
Thanks,
Les
aotte1 is offline   Reply With Quote
Old 02-20-2014, 03:32 PM   #2
walkerb
walkerb's Avatar
Re: 1973 to 78 Stepside Fenders fit 1986?
Yep everythings the same size and fits the same. Only difference is the obvious, wiring and gas tank.
Not sure what your asking about the fuel doors and markers.
What year is your truck?
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 02-21-2014, 10:50 AM   #3
aotte1
The truck is a 1986, C10 Stepside , the differences as I understand are: 1). the fuel tank is on passenger side, (86 is on left side) and 2). the 73 to 78 have marker lights in the rear part of the fenders. Not sure if will use the marker lights or weld up?
I need fenders as mine are rusted at the seam where they bolt to the bed, they were undercoated in that area and rusted beneath the coating to the point of having small holes. To bad because they are only rusted in that area.
Thanks,
Les
Old 02-21-2014, 11:06 AM   #4
aggie91
I'm just glad to be here!
aggie91's Avatar
On the stepside I did for my son, we used aftermarket fenders from a couple of sources. Both fenders I used did not have marker lights or gas filler doors in them. If you need the LH sq filler door, it could be cut out of your original fender and patched into the new one. That way you do not have to fill in the marker lights. We used a rear mounted tank with the filler in the bed so there was no need for the fuel door in the fenders...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
