Old 02-21-2014, 08:22 PM   #26
RANDY COX
RANDY COX's Avatar
Re: 61K10 build
Hey 61K10 glad to see your build, Maybe I'll get motivated on mine, waiting for the weather to break, as it's outside...Love that color..
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 02-22-2014, 01:53 PM   #27
61K10
61K10's Avatar
Re: 61K10 build
63c-10--I thank the ez runs a 404 all my saws are 404 except the 35A which has a 7/16 or something like that.
Mitch--tk had the 305 in it when i bought it. the reason i know it was a 6 is the ft eng mount was cut off the front and re-welded on the rear of the x-member.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-22-2014, 02:18 PM   #28
61K10
61K10's Avatar
Re: 61K10 build
Randy--you will get there------
a few more pic's--there are hours of cleaning parts
t/f case from Jason M.-----thanks again---nice young man.
1961 chevy K10
Old 02-22-2014, 02:40 PM   #29
61K10
61K10's Avatar
Re: 61K10 build
my new fuse block--used org harness. now everything is fused
heater control
t/c shift linkage
1961 chevy K10
Old 02-22-2014, 04:23 PM   #30
RANDY COX
RANDY COX's Avatar
Re: 61K10 build
Hey 61K10 I see your at it again, one piece at a time my friend, I did go and get some gas and put in my truck today and fired her up. I'll be soooo glad when it's spring time..
Lookin good.
1964 BBC 402 4x4
Old 02-22-2014, 07:53 PM   #31
TJ's Chevy
TJ's Chevy's Avatar
Re: 61K10 build
Looks good bud! Hey where did you purchase the wiring harness?
Old 02-23-2014, 01:10 PM   #32
61K10
61K10's Avatar
Re: 61K10 build
T.J.---I had the fuse block from another project from a few rears ago. took my old org. harness apart, cut all the sodered wires apart run new if needed and re-raped harness. now everything is on it's own fuse.
1961 chevy K10
Old 02-23-2014, 01:55 PM   #33
61K10
61K10's Avatar
Re: 61K10 build
ok some body pic's--
bedside looks good till blasting. used one of mine and one i bought and it was full of filler.
put bedsides back on tk for blocking (thats just my idea) helps me see
pic of door dents. dents were on both sides (stops were broken)
black is epoxy and gray 2k primer
1961 chevy K10
Old 02-23-2014, 02:00 PM   #34
61K10
61K10's Avatar
Re: 61K10 build
some more---bored YET? out door paint booth
1961 chevy K10
Old 02-23-2014, 02:05 PM   #35
61K10
61K10's Avatar
Re: 61K10 build
a couple more--don't know if i will watch the 500 or go weld my d/s rocker in--
1961 chevy K10
Old 02-23-2014, 06:12 PM   #36
RANDY COX
RANDY COX's Avatar
Re: 61K10 build
Progress,progress, I like the outdoor garage too if the weather is nice...
1964 BBC 402 4x4
Old 02-24-2014, 03:30 PM   #37
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
Nice work on those bedsides! Are you running stock leaf springs on your K10? I really like the stance of the pic of the rear. It shows good clearance!
I had mine rebuilt and opted to stay with the original height & clearances. Hopefully, it'll look that good. If not, I may have to go back and add a leaf.
'62 Chevy K10
MitchFloyd is offline   Reply With Quote
Old 02-24-2014, 03:39 PM   #38
1963c-10
1963c-10's Avatar
Re: 61K10 build
I agree, nice work on the bedsides. I still need to find some of the e-z-steps for the fleetside. They are scares when looking for them and everywhere when I didn't have a fleetside.
1964 Short bed trailer
Old 02-24-2014, 05:31 PM   #39
61K10
61K10's Avatar
Re: 61K10 build
Mitch--I have 2 more leafs in the rear, built like over-loads. they only raise it about 3/4"
63c-10 they come up on e-bay now and then
1961 chevy K10
Old 02-25-2014, 01:26 PM   #40
61K10
61K10's Avatar
Re: 61K10 build
removing cab and at my buddy's to get blasted and epoxy
1961 chevy K10
Old 02-25-2014, 01:31 PM   #41
61K10
61K10's Avatar
Re: 61K10 build
at the blasters----------a lot of holes showed up---need new rockers/cab corners---
1961 chevy K10
Old 02-25-2014, 01:43 PM   #42
61K10
61K10's Avatar
Re: 61K10 build
some painted pieces------and my paint booth
1961 chevy K10
Old 02-25-2014, 03:44 PM   #43
RANDY COX
RANDY COX's Avatar
Re: 61K10 build
I know it has to feel good to get some paint on there...Looks GoooooooooooooD!!!
1964 BBC 402 4x4
Old 02-25-2014, 03:50 PM   #44
1963c-10
1963c-10's Avatar
Re: 61K10 build
Paint looks damn good!!
Old 02-25-2014, 09:59 PM   #45
61K10
61K10's Avatar
Re: 61K10 build
2 watching--maybe should be in 4x4? but usually they are 67--up.
1961 chevy K10
Old 02-26-2014, 10:35 AM   #46
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Re: 61K10 build
I'm here too! Just watching jealously... LOL
Looking great, keep it up!!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 02-26-2014, 10:43 AM   #47
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
I gotta check the data tag on my '62. I'm hoping it's a 703(Neptune green) color instead of the 503 (Glenwood green). I like it a lot better.
'62 Chevy K10
Old 02-26-2014, 01:37 PM   #48
61K10
61K10's Avatar
Re: 61K10 build
everything is color sanded and buffed. being outside and not a painter, some orange peel needed to be removed. there are some small waves--tiny dents that i missed. good enough for me.
Mitch-- the neptune is hard to take pic's of, it changes color somewhat with different light on it.
1961 chevy K10
Old 02-26-2014, 01:48 PM   #49
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
That's exactly the way they came factory too! lol I don't think they were painted like they are nowadays. But mine will be the same as well. I'm not going for a $10K paintjob. Just something that looks good rolling by.
'62 Chevy K10
Old 02-26-2014, 01:50 PM   #50
j.kirn
Re: 61K10 build
Looking good, keep the pics coming.
j.kirn is offline   Reply With Quote
