Old 02-22-2014, 11:09 PM   #1
67_C-30
I have a radical idea!
67_C-30's Avatar
Question about 71 - 72 4X4 6 lug wheels.
What size was the standard wheel size for 71-72 disc brake 4X4 K10's and Blazers? I see stock trucks with a narrow 15" rims with hubcaps, but I don't know the size of them.
The reason I ask is when I change my '68 over disc brakes I want to run a 6 lug rotors, and I have recently found out that the stock 67 - 70 15 X 5.5's won't clear the calipers. I am going to run 15 X 8" 6 lug steelies in the rear, but I want to stick with a narrower rim on the front, but I would like a wider rim than the factory 5.5's were.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 02-23-2014, 09:27 AM   #2
uncle
Re: Question about 71 - 72 4X4 6 lug wheels.
Pretty sure same width just different offset. If not they are no more than 6".
uncle is offline   Reply With Quote
Old 02-23-2014, 10:14 AM   #3
Fleetline Fever
Fleetline Fever's Avatar
Here's a good thread that will give you a few more options.
http://67-72chevytrucks.com/vboard/s...e+6-lug+wheels
Fleetline Fever is offline   Reply With Quote
Old 02-23-2014, 10:23 AM   #4
Mike C
Mike C's Avatar
I'm pretty sure my Jimmy factory wheels were 15x7. Currently they are mounted on my '69 short step with the original '69 hub caps. I would think this would work fine on your '68 with discs.
This is the only pic I could find easily. The spare is the original '69 wheel.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-23-2014, 05:56 PM   #5
SS Tim
SS Tim's Avatar
15x6" was the base wheel size, 71-72 K5, K10 Pickup and Suburban.
SS Tim is offline   Reply With Quote
