engine bogging under acceleration..
Ok, can someone give me a checklist of what items to look into.
I'm running a gm crate 350 ,all new accessories under the hood. Truck ran great then all of a sudden the other day it is bogging really bad under accelleration, Then it ran ok for a drive, now its back to bogging out really bad. Thanks guys. It ran great for a week or 2 and this just started happening. |
![]() Join Date: Aug 2008
Re: engine bogging under acceleration..
Is it bogging down all of the time now? That may actually be a good thong as it is easier to diagnose a constant problem bs an intermittent one. Are your fuel filters clean? Is the distributor all new as well? Points or electronics? Have you checked the timing with a light?
All new distributor, plugs,new edelbrock carb, fuel filter looked clean, brand new gas tank so it didn't have any nasty stuff it could be sucking from there.
Turned the key, can hear the electronic fuel pump goin. |
My mechanic timed it before I took it from the shop, I gotta have a friend bring a timing light by my house to check it
Oh i forgot to answer , no points newer style hei I believe
my or may not help, but mine was bogging real bad under acceleration and it turned out to be a bad accelerator pump in the carb
Chris Mead Tattoos |
![]() Join Date: Mar 2012
i would make sure the choke is fully open
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Deff check fuel filter, make sure the choke is open. Quite possibly the accelerator pump is bad.
Update, took it back to my mechanic, it was a defective carb I will have to ask which part was defective specifically. summit said ship it back so a new one is in route so that's a plus.
