#6 | |
This bolt you drilled will give you a drill-guide so you will be able to drill into the center of the broken one. [As I see it, drilling into center of a broken bolt is the key to removing it with an easy-out. And it's easy to drill the center of the 'new' bolt while in a press, as well as drilling it 'square'.] After drilling the broken one, heat it with acetylene, hammer the easy-out into the hole, and carefully back the broken bolt out. I've used this technique several times where a previous mechanic wrung off starter bolts--up inside the bell-housing bolt-holes--couldn't even see the bolts' ends, but the technique has NEVER failed me. Good luck, and pass along the idea to others facing this scenario when (IF) it works for you. Sam |
| Bookmarks |
