Old 06-13-2013, 04:38 PM   #1
8door
Not too old to learn
Tie rod grease cups made in USA?
I bought a set of new tie rods included the grease cups, about two years
ago and just now went to install them and the rubber cups are split.
Made in China .
Anyone know of a maker of just the cups made in USA ?
All I can find are Chinese made repros from Napa, O'Rielly, Dorman etc.
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 06-13-2013, 05:40 PM   #2
Lee H
Lee H's Avatar
Re: Tie rod grease cups made in USA?
Don't know of any good quality rubber ones but you can get polyurethane ones from Energy Suspension. Tie rod end boots part number 9.13119G contain two boots, about $4 bucks. Ball joint boots part number 9.13126G contains two upper and two lower boots, about $9 bucks.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have all original numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 06-13-2013, 08:13 PM   #3
8door
Good tip I fund them at Summit and I'll look more around here.
That's about the same price for the so called rubber ones that split.
Old 02-24-2014, 02:49 PM   #4
dave-68
Lee - Do you know if the energy suspension ball joint boots you mention fit '67 thru '72? I need lower boots for my '68 (same as 8door) and noticed you've got a '72. I know there's some difference in the ball joints but wasn't sure if was enough to make the boot a different part number.
dave-68 is offline   Reply With Quote
Old 02-24-2014, 03:09 PM   #5
Lee H
Lee H's Avatar
I'm running these tie-rod & ball joint boots on my 72 C10, my 65 Vette, and my 75 Vette. About two weeks ago I installed them on my friends 69 Camaro.
Old 02-24-2014, 05:02 PM   #6
michael bustamante
michael bustamante's Avatar
Im doing the drop spindle convrrsion now on my 67 and the original ball joints cups are still intact! I couldnt believe it. You know t huh ose are american made.
1967custom
michael bustamante is offline   Reply With Quote
Old 09-21-2017, 01:35 PM   #7
PaPaStewySnipes
I have a '71 gmc c15.
Went to AutoZone and part number they pulled up for tie rod end boots was 9.13120G (BLACK) DEMINSIONS - 1 5/8" top, .65" Taper. Is that correct part. I meausred my removed boot and that was exactly the same. Fairly sure the boot is not stock, rods were replaced and I tore one while using a pickle fork.
PaPaStewySnipes is offline   Reply With Quote
Old 09-21-2017, 05:28 PM   #8
StingRay
StingRay's Avatar
I think Energy suspension has generic polyurethane ones that work. I had put some Moog parts on one of my trucks and replaced the stock boots every year. Moog sent me new stuff but it faithfully fell off every year. Sad.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 09-21-2017, 06:04 PM   #9
72_swb
72_swb's Avatar
^Sad to here about moog. There suppose to be USA made. But I've never had the same issue as you with moog. 8 years on some. Still strong
72_swb is offline   Reply With Quote
Old 09-21-2017, 09:17 PM   #10
mike16
my origonals are still good.
check Corvette parts vendors. Thay would have some that look origonal and are poly
mike16 is offline   Reply With Quote
