#26 |
Re: HEI Problem
#27 |
Re: HEI Problem
Tie directly in the pink wire from your iginition switch straight to the HEI, thats how mine is 22 years ago.....
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#28 |
![]() Join Date: Oct 2012
Re: HEI Problem
You can tap into a full 12 volts easily at the fuze box using one of the "Ignition Unfused" terminals. Or you can tap a full 12 volts from the ignition switch as indicated.
I believe you can then eliminate the wire runningh from the starter to the dizzy... I'm guessing with full time 12 volts you are 97% percent fixed.....after that, with luck, it'll simply be inspection and tuning. |
#29 |
![]() Join Date: Mar 2013
Re: HEI Problem
Rich...is this the pink wire you are talking about???? 1st picture. Second picture....I noticed on my fuse box where my finger is pointing..it says "Ignition unfused" will that supply enough voltage to the hei? And or work?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#30 |
Re: HEI Problem
The pink wire from your ( after ) ignition switch, anything before that is not swtched...back of your switch will be marked ign or run.
This pic from Cragers post, ign post at the 11:00 position... ![]()
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip Last edited by Rich 5150 69; 02-19-2014 at 09:21 PM. |
#31 |
![]() Join Date: Sep 2009
Re: HEI Problem
don't run it to your fuse box extra terminal. follow the pink wire back to the fuse box and install it there. you may have to remove the fuse box+
#32 |
![]() Join Date: Jul 2012
Re: HEI Problem
Bump
#33 |
Re: HEI Problem
Well...my new HEI works like a dream. I ended up hooking it to the starter solenoid. Works great, burns the fuel no issue. Plugs are now running a tad hot, but since I run 92 octane I should be fine. All the wiring around the valve cover and by the starter has been loomed up since the picture was taken.
#34 | |
Re: HEI Problem
#35 |
Re: HEI Problem
When running a hot spark, and big carb..you want as much octane as possible. Especially when your spark is advanced. Low octane will cause pinging or detonation, which will result in severe engine damage. Older engines like high octane low ethanol. I run 92 E10...which is highest you can get for under $4 per gallon...we have a station that sell 100 octane...but its at over $5 per gallon. Anytime you run a performance engine or performance parts on your engine...running better fuel always pays off.
#36 | |
Re: HEI Problem
#37 | |
Re: HEI Problem
#38 |
Re: HEI Problem
Bout 95 in all cylinders last I checked. Brand new from factory was 8:0:1...and that's MAYBE 130 pounds....so...runs good.
#39 |
Re: HEI Problem
