1964-1966 Hood bumper set ? Help.....
Can someone tell me where these go on the hood ?
Thanks in advance. ![]()
Always a place in my heart for old Chevy trucks ![]() My build thread-project truck dream 65" http://67-72chevytrucks.com/vboard/s...d.php?t=510863 |
Re: 1964-1966 Hood bumper set ? Help.....
I pushed them into a small hole under the front lip of the hood on my truck.
1965 Chevy C10 Stepside Shortbed--2012 370Z Base Gun Metallic--2020 Chevy Silverado RST Crew Cab |
#3 | |
There were no bumpers of any sort on the front of the hood when I bought the truck from my uncle (originally my grandfather's truck--he purchased it new in 65). When the kit came in I had no idea where the round ones went either, but that looked like a good place to me, and they fit.
#6 | |
i think there should be at least 4 more because there are six holes same size but they only send 2 i was gonna order another set to fill the other holes
#9 | |
Can't remember if the rivets go on the hood or cowl. The round rubber ones go in the front and as far as I know they were not specific to 60-61 as after a little trimming they fit on my 65. Hope this helps. Cal. |
OK, I should have looked before made my last statement.
I just looked at mine and there are the 2 soft round rubber ones on the front of hood as pictured. The soft ones so as not to rub your paint off. On the back side of hood there is a spot where the rectangle harder rubber bumbers are rivited on with 2 rivits each. This is located where the hood would sit closed 1/2 way down on the cowl extensions. The cowl has a spot where you can see where your hood would rest. I stated earlier that the other 2 bumbers went on the cowl, not so my mistake. On mine there is no bumbers on the cowl but only on the hood where it mets the cowl. I could not see how it would be mounted there as there are no screw or rivet holes even if it was missing. As for the 2 square bumbers with one hole in them I don't know where those go. Sorry for being long winded but I wanted to clear up my mistake. Cal. |
#11 | |
I believe these bumpers on Dad's 66 are originals (not replacements) ... Front: ![]() And rear: ![]() |
#12 | |
Cal. |
