Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 01-28-2014, 03:53 PM   #1
energy-arc
Early style tach cluster
All gauges were working when I pulled the cluster. Includes tach wire harness. One broken / missing mounting tab. $180 includes shipping. (ups ground) Thanks, Jody tavia@plateautel.net (575)-513-2122
energy-arc is offline   Reply With Quote
Old 02-27-2014, 07:17 PM   #2
HeavyMetalThunder_81
HeavyMetalThunder_81's Avatar
Re: Early style tach cluster
Still have this? And will it work in a '79 that didn't originally come with the tach option?
-Jonny B.
1979 Chevrolet K20 Scottsdale: GM350/SM465/NP208
1979 Jeep Cherokee Golden Eagle: AMC360/TH400/D20
1999 Dodge Ram 2500 Larime SLT: Cummins 5.9L 24v/47RE/NP241
HeavyMetalThunder_81 is offline   Reply With Quote
Old 02-27-2014, 07:30 PM   #3
energy-arc
Hey partner, thanks for the interest. That cluster is gone but I do have another one just like it. With wire harness. I think it's a direct fit if you have mechanical oil pressure gauge in your 79. $180 includes shipping. Thanks again, Jody
Old 02-28-2014, 08:17 AM   #4
That sounds great! I have an electronic oil pressure gauge but would rather have a mechanical. Do you have any pictures? Also, off topic, do you happen to have any gauge/dash bezels for a '79?
-Jonny B.
Old 02-28-2014, 07:21 PM   #5
Prong
That's a 73-75 cluster (the amp gauge gives it away). If you try plugging an amp gauge setup into your volt gauge setup, you'll wind up with crispy wiring.
Prong is offline   Reply With Quote
Old 02-28-2014, 07:31 PM   #6
ray_mcavoy
Just an FYI, the early clusters (73 - 75) used an ammeter so they won't be a direct plug-in swap into a 76 or newer truck.
It'll still fit but you'll have to either (A) modify the truck's wiring to work with the ammeter, or (B) modify the cluster to accept a 76-up voltmeter. Modifying the cluster to accept a voltmeter will likely be the easiest.
Also be aware that GM made some significant changes to the cluster plug pin-out in 78. So you'll have to re-arrange some wires on that plug to make everything match up.
ray_mcavoy is offline   Reply With Quote
Old 02-28-2014, 08:01 PM   #7
energy-arc
Hey ya'll, Thanks for the excellent info.
Old 03-01-2014, 05:26 PM   #8
PM sent.
-Jonny B.
