#26 |
Don't say "Oops!", Doctor
If the brake light comes on, what is it indicate?
That the brake light is working, of course! ![]() Seriously, though. I believe it's just a low fluid warning. It could be a pressure sender, but I'm not 100% certain.
'Mutt 1968 CST LWB: R.I.P. 1967 Chevelle: TPI 454 beast 1967 C10 SWB: Claimed when Bumpster didn't put it on his list |
#27 |
Back in the sticks
Usually it indicates that the fluid is low or the rod is bottoming out. If it bottoms out it is usually out of fluid or out of adjustment. Someone correct me if I'm wrong. I don't remember where I got my tach, but I bought a repro and its a beautiful thing. Just wish I could figure out how to make the lights look red at night like those pontiac dashes.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#28 |
So in my '68 sub with gauges I could just swap in the tach itself ?
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ '68 GMC Sub 4X4 new project ![]() '69 Pontiac GTO 20 year project ![]() ![]() Never hold your farts in. They travel up your spine, into your brain, and that's where you get sh*tty ideas from. |
#29 |
Back in the sticks
With a little cutting and new lens and wiring, yes. You have to cut out the hole for the tach lens in the black part of the dash, then cut a hole for it to mount in in the outer part of the back as well. Screw it to the plates, wire it, and off you go. I also bought a new tach type printed circuit, but your could get around that with a little more work as well. Jeff.
#30 |
42.00 for this baby
#31 |
its all about the +6 inches
To make your lights glow red, take apart your insterment panel, and paint all that funny looking green metal white.
Then reasemble it all with red lights. |
#32 |
ur smart!
70 longbed 496/th400/Ford 9" |
#33 |
Old member
I was just reading this and noticed no one said anything about the gear driven tachs that came in them. I now for a fact that they had them because I bought one out of a truck in the yard years ago before I found my electric one. If I remember correct it was a 427 motor, what the guy said was a heavy duty motor. I asked my dad what that meant and he said it just meant more metal between the water passages. (DAD) 31 years in Chevy trucks. Retired now. He work at the Chevorlet ZONE Office in Charlotte NC.
shuttermutt, I would think it means the same thing as it did before, ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
