Closed Thread
Old 03-02-2014, 02:14 PM   #3226
agnes the dog
agnes the dog's Avatar
Re: What Did You Do With Your Truck Today ?
It's water vapor that comes from the moisture in the air above the fuel that condenses when it gets cold. Since fuel is lighter than water, the condensation settles in the lower part of the tank or fuel line where it can freeze. It's always a good idea to keep a good amount of fuel in the tank especially when it gets really cold. The condensation comes from moisture in the air above the fuel (mostly). If you limit the amount of air above the fuel, you are limiting the amount of moisture in the system. The antifreeze additives are made to absorb the water in the system so it can't freeze.
Just because you can, doesn't necessarily mean you should.
1959 3100 stepside 355 + T5
agnes the dog is offline
Old 03-02-2014, 02:18 PM   #3227
MARTINSR
MARTINSR's Avatar
Ahhhhhhhhh, interesting. Understand I was out working on my car yesterday in a tee shirt.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline
Old 03-02-2014, 03:13 PM   #3228
Jack Guzman
Most gas has some water in it. Water vapor in the fuel line freezes and blocks the line.I think it's less common these days because the alcohol added to modern gas absorbs the moisture.---No expert---Jack
Jack Guzman is offline
Old 03-02-2014, 06:40 PM   #3229
OrrieG
OrrieG's Avatar
Won't happen in CA except maybe in the Sierra's. When it gets really cold around here fuel lines and carbs will freeze, in the 80's my 235 equipped truck was the only vehicle that would start, wifes Honda was frozen solid at 15 below. Later in the 90's same thing happened but my DD then was 41 Master Deluxe with 216, again it was the one that would start that cold. Big carb jets and passages made the difference.
OrrieG is offline
Old 03-02-2014, 11:07 PM   #3230
mr48chev
mr48chev's Avatar
Snow, 27 degrees and a Nasty wind chill today. It was a planning and research day. That's my story and I'm sticking to it. I had serious plans to drill the rivets out of the front crossmember (GMC) and fit the Chevy crossmember in place.
My ongoing truck projects:
mr48chev is offline
Old 03-03-2014, 11:04 AM   #3231
dubie
dubie's Avatar
We got the front clip, cab, doors and rear fenders all sanded with 180 grit so we can get some epoxy primer sprayed. We only have another hour or so of sanding and then I will treat some of the surface tugs to the CLR and scotch brite pad treatment.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline
Old 03-03-2014, 07:08 PM   #3232
capnduane
capnduane's Avatar
Its been raining steadily here in So Calif. the last 3 days. Today the sun finally came out and I took a few minutes to install the stainless tail lights that 57chevyman posted about last week. They look alot better than my Walmart $6 trailer lights that I had on before. Next project will be to install my blue dots into these lenses.
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder"
capnduane is offline
Old 03-08-2014, 04:02 PM   #3233
Nordic
Nordic's Avatar
added new gauges and cup holders
Nordic is offline
Old 03-09-2014, 09:04 PM   #3234
dubie
dubie's Avatar
Sprayed some epoxy primer
dubie is offline
Old 03-09-2014, 09:59 PM   #3235
apache200
apache200's Avatar
Truck looks good dubie
1958 Chevy Apache Stepside
1955 BBW Fleetside
apache200 is offline
Old 03-09-2014, 10:12 PM   #3236
Highsider
Highsider's Avatar
Yep, the shot of primer sure changed the look.
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline
Old 03-09-2014, 10:57 PM   #3237
youngrodder
youngrodder's Avatar
Nothing pretty. I managed to remove my rear suspension. Man was that a dirty job. I'm glad this part is over with.
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline
Old 03-10-2014, 12:39 AM   #3238
OrrieG
OrrieG's Avatar
Good weekend. Got the wiper fluid hose routed. Dropped in a battery and started checking circuits. Everything is working so far, except for a couple of things that are not critical; transfer case 4wd indicator and over-ride switch for the courtesy lights I installed. More info in the build thread.
OrrieG is offline
Old 03-10-2014, 02:05 PM   #3239
lazypineapple
lazypineapple's Avatar
And headliner in black suede. I made door panel from left overs
Inside door pull @Walmart
lazypineapple is offline
Old 03-10-2014, 02:09 PM   #3240
lazypineapple
Headliner pic
Old 03-10-2014, 02:10 PM   #3241
OrrieG
OrrieG's Avatar
I like those cup holders! Nice looking dash assembly...
OrrieG is offline
Old 03-10-2014, 03:08 PM   #3242
DaveCt
DaveCt's Avatar
Finally had decent temps. this past weekend.
Reassembled the front end w/ drop axle and disc brakes.
Got to finally put the old girls new wheels on her.
DaveCt is offline
Old 03-10-2014, 03:43 PM   #3243
capnduane
capnduane's Avatar
Lookin good DaveCt! Beautiful workmanship.
Old 03-10-2014, 04:52 PM   #3244
sanford&daughter
sanford&daughter's Avatar
installed my dads new seat cover
sanford&daughter is offline
Old 03-11-2014, 07:39 PM   #3245
53farm
Got my 1953 3600 with a 235 in it to start and run on its own! Probably not a big deal for many here, but I wrestled with it a bunch last fall and it just wouldn't cooperate. It would run if I poured gas into the carb, but thats it. Today I put a new fuel pump on it, although I think the old one is still good, just installed wrong. Put a fresh fuel filter on it too. Took fuel line off, ran a little water into it and blew it out to ensure it was clear. Put it back together, put the end of the fuel line straight into a gas can, poured a little gas into the carb and it fired right up...and kept running this time! Let it run and turned it off. Started and let it run several more times over the course of an hour or so, and it started and ran every time on its own. I'm reinvigorated! A few more weeks and hopefully it'll be warm here for good and I can really tear back into it.
I'm planning to sign up for the local community college welding class this summer session, psyched for that! Needs floors and some other spots patched. Short term goal is to have it on the road this spring/summer for local use. Medium term goal is to have it in good enough shape to drive to Texas, sampling BBQ the whole way there, in April 2015 for a friend's wedding. With 13 months to go, I'm pretty sure I can make it happen. Not totally sure what the long term goal is for it yet. Still would like to do a 4x4 conversion on it at some point...or find a second one to do that to
53farm is offline
Old 03-11-2014, 07:39 PM   #3246
53farm
Sorry for double post, wont let me delete.
53farm is offline
Old 03-11-2014, 07:55 PM   #3247
yossarian19
I made & installed the B+ to starter wire, managing to route it away from the exhaust & all the sharp edges.
Just a few more wires to go...
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline
Old 03-11-2014, 08:06 PM   #3248
49tomchevy
Painted the bed strips and finished, stained and cleared the sassafras wood.
49tomchevy is offline
Old 03-11-2014, 08:22 PM   #3249
lgoodso1
I ordered my fuel tank today for my 57 3200, started on disassembling the 327 engine I plan to put in it
lgoodso1 is offline
Old 03-11-2014, 08:28 PM   #3250
Dan in Pasadena
Dan in Pasadena's Avatar
Dave, who dropped your axle and how many inches? Did you have the king pins rebuilt? I'm curious how well it steers afterward? Does it "wander" like my '55.2?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline
Closed Thread
