Old 03-02-2014, 04:51 PM   #1
notallthere
Spare tire carrier
Once it warms up (hopefully before April) Ms Notallthere and I have to go out to some of the Upulls in the Michigan area for a parts run. I am a hopeless romantic and take the wife.
Anyways I was wondering if anyone has considered or done a newer style spare tire hoist under the bed of their truck?
If you have done it do you have pictures of it and how does it work?
notallthere is offline   Reply With Quote
Old 03-02-2014, 06:19 PM   #2
1774btcrew
1774btcrew's Avatar
Re: Spare tire carrier
I haven't done it but my friend has these on both of his squarebody trucks. He uses the Ford ones as he builds Trophy off road trucks and that is what is available to him. I don't have any pictures but he seems to be really happy with them.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 03-02-2014, 07:13 PM   #3
notallthere
Thanks I will have to check out the Ford ones to see. I may pick up a couple just to see. Fortunately I should be able to do a visual check on junk truck before I take one home.
Old 03-03-2014, 09:57 AM   #4
1981Stepside
1981Stepside's Avatar
Just be sure to lube the mechanism regularly. Years ago, working at a tire shop I had to cut quite a few winch cables to get the spare out when customers forgot about it under there and the mechanism seized.
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 03-03-2014, 11:18 AM   #5
Keith Seymore
Keith Seymore's Avatar
I haven't done one on my truck, but I did use the GMT400 style on my open car trailer.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-03-2014, 01:24 PM   #6
notallthere
That is actually a good idea for the trailers. I may have to copy that on my trailers.
Old 03-03-2014, 02:22 PM   #7
Keith Seymore
It used to be up on top of the tongue in that same location, but as the car got progressively lower it didn't fit there anymore.
K
1979-1986
1986 - 2019
Old 03-06-2014, 10:43 PM   #8
notallthere
Did you use the extension arms to take the carrier to the bumper or just the winch itself?
Old 03-07-2014, 07:04 PM   #9
mrolds88
Then you can put a power window motor on it and raise and lower it without the cranking.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 03-07-2014, 07:23 PM   #10
notallthere
That would be a damn good idea.
