Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Coilover spring rate
Ok guys, Im ready to order my front coil overs so I can finally move on to finishing the rear of my chassis. For those of you running coil overs what spring rate are you using? I will have the C4 (obviously) front and rear suspension and running a 5.3/4l60e combo.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
![]() Join Date: Mar 2011
Re: Coilover spring rate
Josh, I think a lot of it has to do with the length of shock and length of spring. On my MII front end which has an 8" coil spring, I'm using a 700# coil spring. This is also what QA1 recommended for my truck, engine, ac, etc....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
Thanks man, From my reading it looks like 500# springs is what I would use. Hopefully someone with the C4 swap will chime in.
Thanks man, could use any other specs you have as well. Length extended, compressed, etc... Looking at some Bilsteins Thanks
Elev8r Man
Between 450 - 500# is what they said I needed for mine. I am using the full rear suspension w/ mono leaf though. Only coil covers in the front
1955.2 C4 Carry-all / Suburban ![]() 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
Would love that part # if possible. Didn't think they would be 650#!!
650# should be much closer than the 500# rate you first mentioned. The Vette lower control arm uses a more outboard coilover mounting point than most. This allows a little lower spring rate to be used, but the 500# rate with the stock engine location may be too soft.
Sounds great guys. I'll go with the 650# ones if that's what FlatOut is selling. They did the R&D so I'll trust that. Anyone know the extended length, mounted length, and how much travel they have?
