Old 03-02-2014, 01:58 AM   #1
BossHogg69
motor exploder
BossHogg69's Avatar
VHT Engine Paint
Just wanted to share my experience with VHT's line of 'High Heat' Engine Enamels. Painted a new McLeod scattershield and my old TKO trans today. Scuffed them both with a red 3M Scotchbrite and then hit them with some aerosol wax/grease remover. Then blew off the parts with some compressed air to make sure everything was dry and dust free - then 3 coats of VHT High Heat Engine Primer, waiting 10 mins between coats. Once that was good and dry (to the touch), I shot on 4 coats of VHT High Heat paint, waiting 10-12 minutes between coats.
Once I get this stuff road tested, I'll follow up with some opinions on how it holds up to some hard driving. Until then, all I can say is that is lays down really well and looks pretty decent sitting in my garage. I have used the VHT Roll Bar & Chassis paint before with good results, so I figured I'd give their engine paints a try.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 03-02-2014, 04:27 AM   #2
Gumby
Gumby's Avatar
Re: VHT Engine Paint
Its very forgiving, originaly painted my T5 with cheap blue 99c paint, some off comments on why bother, so I hosed it down with neon green VHT engine paint. 10+ years later, still green.
Gumby is offline   Reply With Quote
Old 03-02-2014, 06:55 AM   #3
bigmac73
bigmac73's Avatar
well the high heat paint is garbage, i sanded and cleaned my headers for hours
and applied the primer and paint, the stuff melted off like a birthday candle after a few hours of operation, now i am stuck with rusty ,burnt looking headers
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 03-02-2014, 07:28 AM   #4
Gumby
Gumby's Avatar
rub your rusty headers with silver anti-sieze, use your hands to really rub it in good and spread it around well.
stinks for a few, don't come off.
Old 03-02-2014, 07:37 AM   #5
bigmac73
bigmac73's Avatar
i take that it will bake in??
Mike
Old 03-02-2014, 08:17 AM   #6
Gumby
Gumby's Avatar
oh yea, its an old trick all over the web, it doesn't come off once baked in.
Old 03-02-2014, 11:45 AM   #7
mitch1965
mitch1965's Avatar
I used VHT primer and paint on my exhaust manifolds 15k miles ago, and they still look good. I was really thorough about cleaning with alcohol first, but only wire brushed them to prep.
'99 K1500 Tahoe, 2dr, barn doors - 350/ 4L60E, 3.73
'01 K2500HD Silverado Ext Cab - 496/ Allison, 4.10
mitch1965 is offline   Reply With Quote
Old 03-02-2014, 06:05 PM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
I had some 25 year old Clifford L6 headers hot tanked and bead blasted then hit them with VHT Cast Iron Grey hi-heat paint. Still good, since 2005.
Old 03-02-2014, 06:32 PM   #9
cableguy0
Headers are tricky. The big issue is that they get so hot. The other problem is that if the headers have been run on a vehicle there are combustion gasses and soot trapped in the metal. The best method for cleaning them is in a hot tank a machine shop. That will remove all the contaminants. If your engine is running a bit lean or even a bit rich the headers will get super hot and most paint cant survive.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 03-02-2014, 07:41 PM   #10
bigmac73
bigmac73's Avatar
I agree i have a few quarts of Heat Resistant Aluminum paint I got from work ( standard naval issue), i used that first and it only last a few months under the heat and i sanded and cleaned for days doing the prep
Mike
Old 03-02-2014, 09:30 PM   #11
BossHogg69
motor exploder
BossHogg69's Avatar
VHT has a line of high heat header paint also, but it has a much higher heat rating than the engine paint. I used the VHT high heat engine paint on the brakes of my '05 GMC (front calipers and rear drums) and it still looks good and hasn't peeled off after a year.
Adam
engine, high heat, paint, vht
