Old 03-02-2014, 11:32 PM   #1
ho70
ho70's Avatar
Our truck big blocks......4 bolt mains??
Since they were truck motors and I do not want to take mine apart to inspect it....were the truck big blocks 4 bolt mains?
ho70 is offline   Reply With Quote
Old 03-02-2014, 11:36 PM   #2
67ctener
67ctener's Avatar
Re: Our truck big blocks......4 bolt mains??
I'm gonna go with 2 bolt. I'm almost positive my 71 402 was a two bolt main
67ctener is offline   Reply With Quote
Old 03-02-2014, 11:38 PM   #3
67 chevelle
67 chevelle's Avatar
my guess would be 2 bolt , they are 1/2 inch bolts
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 03-03-2014, 11:56 AM   #4
tony58
No if you're referring to light duty trucks 1/2 and 3/4 ton. Only high performance cars, those with the large square port heads got 4 bolt blocks. The heavy duty trucks with tall decks may have had 4 bolt mains but I think most of those were two bolt also.
tony58 is offline   Reply With Quote
Old 03-03-2014, 01:31 PM   #5
Fitz
The only 396/402 engines with 4 bolt mains were the L78 Corvette and Z16 Chevelle motors. All of the C-10 trucks were 2 bolt main bearing engines.
Fitz is offline   Reply With Quote
Old 03-03-2014, 01:35 PM   #6
RenoKeene
Florida Edition
RenoKeene's Avatar
2 bolt...here is my original 70 402 for reference.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 03-03-2014, 03:31 PM   #7
GRX
GRX's Avatar
As has been said countless times ... don't get yourself all bunched up over stock 4-bolt set ups. Unless the outer bolts are splayed, there is little to no advantage.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 03-03-2014, 06:24 PM   #8
myyamr7
myyamr7's Avatar
While on this topic, what about the crank shaft? I recently rebuilt a 1972 402 out of a C-20 (was told it was the original, but I don't think it was) and when I pulled the crank and dropped it off at the machine shop, the guy looked at me and asked what the crank came out of? It was forged steel, cross drilled and hardened? He said most cranks he cuts from that generation are cast
Mark
71 C10 Cheyenne
12 Aprilia RSV4
myyamr7 is offline   Reply With Quote
