Old 03-04-2014, 02:57 PM   #3
walkerb
walkerb's Avatar
Re: Transmission woes!!!
Originally Posted by crashz View Post
Likely an accumulator is somehow stuck. Based on that, and possibly a 40 year old transmision, I'd be tempted to rebuild it. Have a reputable local transmission shop go through it, replace wear parts, seals and any defective hard part, install a new torque converter (they do get worn over time) and install a new fluid cooler, bypassing the radiator cooler. i like to add a transmission temp guage on each of my rigs too.
The 400 is supposedly the easiest transmission to rebuild, is plentiful, and has been around since the stone ages. Usually they can be done for a good price with modern wear parts.
When you say bypass the radiator cooler, are say not use it at all?
Im not sure I would do that, even with a one with a fan. Why not tap it in after the radiator?
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
