Old 03-04-2014, 06:33 PM   #1
myyamr7
myyamr7's Avatar
Correct carb for 72 402BB?
Tried searching for the part numbers here, but didn't come up with much. I have a 72 402 BB out of a c-20, that was said to be an automatic. From the little info I found, most carbs for an automatic (I know the BB comes with a TH400 with electric kick down, but from what i've seen, the carbs still have the arm or the cable) have the extra bracket on the linkage for the kick down cable, but mine does not have that.
The carb number is 7042206 QA with 1172 under it.
I was told it worked good, so i didn't plan to rebuild it..though second guessing that choice now. Whoever rebuilt it last did not put the choke assembly back together correctly, so the choke could only open half way
Mark
71 C10 Cheyenne
12 Aprilia RSV4
myyamr7 is offline   Reply With Quote
Old 03-04-2014, 08:52 PM   #2
geezer#99
geezer#99's Avatar
Re: Correct carb for 72 402BB?
According to Lars you have the correct carb.
http://www.digitalcorvettes.com/foru...ad.php?t=88376
Did you get the choke fixed?
Old 03-04-2014, 10:14 PM   #3
myyamr7
myyamr7's Avatar
Cool, thanks for that link.
Yes, I got the choke working correctly. Not sure what the part is called that was in wrong, but it sorta looks like a weight and triggers the secondary lock when the choke is on? It was on the wrong side (under) the trigger mechanism, and the part would hit the vacuum port that sticks out allowing the choke to only open half way. I moved the part to the top and it all works as it should now
Mark
71 C10 Cheyenne
12 Aprilia RSV4
Old 03-04-2014, 11:59 PM   #4
71 super
71 super's Avatar
A correct bb carb will not have the kick down arm on it because of the electric kick down. The carb shaft will be like a manual truck.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 03-05-2014, 08:11 PM   #5
myyamr7
myyamr7's Avatar
A quick search of the for sale section here shows several big block carbs with the same number that mine has, that have the kick down arm on them in the pictures.
That being said, a closer inspection of mine shows that the kick down arm was cut off at some point for whatever reason.
I need to fab something up for an arm, I'm running a 200-4R, so I need the detent cable to work correctly
Mark
71 C10 Cheyenne
12 Aprilia RSV4
