Old 03-05-2014, 07:23 PM   #1
Cody Sanchez
Charcoal canister
I was wondering if anyone had any good references on how lines from charcoal canister to carb and intake would be ran.... strong scent of gas in exhaust and notice only line was from gas tank....pics would help a a lot.
Cody Sanchez is offline   Reply With Quote
Old 03-05-2014, 08:43 PM   #2
bigmac73
bigmac73's Avatar
Re: Charcoal canister
scent of gas in exhaust means you are running rich, charcoal canister is just to keep vapors from fuel tank out of the cab and out of atmosphere, it has nothing to do with exhaust,
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 03-05-2014, 08:45 PM   #3
Daman
I have one from the tank and one from the vacuum on the carb. I'm not sure if that's correct but the previous owner kept the engine totally stock "except" the carb
Daman is offline   Reply With Quote
Old 03-05-2014, 08:56 PM   #4
BugzC10
BugzC10's Avatar
Here's a few illustrations of how the gas tank is connected to the charcoal canister and the line to do so. Ingnore the comment in red on the tank picture. The charcoal canister is marked where the lines or hoses go.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 03-05-2014, 10:42 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Only thing I know about them is if you take it out and shake it and it doesn't rattle it isn't any good..... There are threads about rebuilding them and purchasing new ones on here somewhere.
LockDoc
Leon
