Traction Control 5.3 2003
Is there a option for turning the traction control on or off in the tune process.
or is there even a traction control option? At what point, RPM or speed, or throttle position can you set the down shift from 2nd to first, and from 3rd to second, or is this even possible?
#2 | |
![]() Join Date: Apr 2005
Re: Traction Control 5.3 2003
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#3 | |
meowMEOWmeowMEOW
I think for real Trac you need ABS and a yaw sensor. In the vette's it can actually pulse the brake and reduce dbw throttle input. I'm not sure if there are wheel speed sensors, but it has some way of comparing wheel rotation to detect slip,
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#4 | |
#5 | |
