Sleep-Deprived
I went and pulled this linkage for my 292 I-6
on Friday, and was lucky to find the pieces. The bracket that mount to the engine seems to be a weak point and is not available thru LMC. When I brought everything to the counter, he says $35. I wasn't happy with the price, but didn't say anything, instead asked what he wanted for ps gear box. $75 was the price. Told him all I brought was $100. He wouldn't take it. I didn't go back for the ps box. You'd think $10 wouldn't be that much for a place that doesn't take checks or credit cards. Went to another yard on Saturday and got the ps gear box for $65 from some guys I've done business with before. Sorry for the rant. I should have asked before I bought the linkage, but what are my options? I'm thinking of cleaning up the welded bracket and using it. The rod that comes thru the firewall is also worn (as they all seem to be). Any solution for this? Custom fab a rod with a sealed cartidge bearing sounds good to me.
1971 K/10 Long Fleetside 350/350 - 6" Lift 1969 C/10 SWB 292 - Sold It |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Degrease everything thoroughly and weld up all of the worn spots. Then, grind the welds down to the proper shape.
On worn holes, I weld it completely closed, grind its smooth on both sides and redrill the new hole.
Sleep-Deprived
This part is half worn away.
I'll see if I can build it up by welding it and make it round again. I'd like to put a sealed bearing in this joint, or at least a brass bushing. It should be better than new when I call it good.
1971 K/10 Long Fleetside 350/350 - 6" Lift 1969 C/10 SWB 292 - Sold It Last edited by 69_hafton; 12-28-2003 at 09:43 PM. |
All right Hafton, I can see you're a pervert when it comes to fixing stuff. That's okay though, you're not alone. I too am an obsessive pervert when it comes to improving simple stuff.
Here's what I would do: You can buy a female threaded rod end from Summit. Cut the end off of the rod and then cut some thread on the rod. Finally, screw the Summit rod end on. Then hold the rod end to the z-bar with a Grade 8 bolt and locknut. Congrats, you now have a bearing clutch linkage. Total cost under 10 bucks.
Sleep-Deprived
Firefighter - LOL, what a choice of words!
Thanks for the tip though, I hadn't looked around at hardware yet. That threaded rod end looks perfect! Yeah, I seem to do a restomod on every vehicle I get. This was supposed to be a work vehicle. But it has to be reliable. Is there a smiley for a pervert? Probably wears sunglasses.... ![]()
