Old 03-05-2014, 06:59 PM   #1
farmero
What is best NV4500 oil?
People tell me Castrol synthetic. I am having a hard time finding it around here. Must I special order this gold? I have these brands available local. Mobil 1 synthetic, Royal Purple synthetic and a couple others. Prices range from $9 up to $20 for the Mobil 1. I just busted my nuckles rebuilding this trans and don't want to make a wrong move on the oil. This is for my work truck and grain hauler.
farmero is offline   Reply With Quote
Old 03-05-2014, 11:09 PM   #2
ryanroo
ryanroo's Avatar
Re: What is best NV4500 oil?
the GM or dodge fluid is what i run. i forget the name of the fluid but it is the same from either brand. its not cheap, but it is what the syncros want.
Chrysler # 4874459
GM #12346190
castrol syntorq is also the OK i believe. i usually run the dealership stuff. who ever has the better price. there are a few places on the net that you can order it as well.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-05-2014, 11:17 PM   #3
Redcap
Castrol SynTorque 75W-90.
The GM dealer part number is PN 12346191. It is the exact same oil.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 03-06-2014, 12:00 AM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Dodge calls it synchromesh. We get it from our supplier in Minnesota and it's about half the price of every where else.
Ryan
1969 Chevy milk truck
Old 03-06-2014, 08:44 AM   #5
farmero
OK guys, I did more checking last night and the general agreement is to use Castrol Syntorq (Watch that spelling closely) and Dealer oil. I had purchased some Royal Purple and some told me that was the worst thing I could put in the trans. Returned that last night. I have a connection with GM so I will find out today about oil from them. Thanks
Old 03-06-2014, 09:17 AM   #6
roxxx
Long thread on the dodge forums.. the oil is like gold ... unless you are crafty and cross it with a GM part number and buy it for 5 bucks a litre on sale in Canada anyway
gm (PN 12346191) this is one of the gm part numbers
roxxx is offline   Reply With Quote
Old 03-06-2014, 09:35 AM   #7
doubleclucker
doubleclucker's Avatar
Heres the stuff for us North of the Border guys-
Right from the stealership...'Genuine Generous Motors'
#10953477
$25 dollars a litre taxes in ... OUCH!
mopar-4874459 subseded 4367579 or vice/versa costs even more!
I used the factory fluid then if I have a synco go bad I can't easily blame the oil I used; but if i used anything else well...
100:1 low gear!
doubleclucker is offline   Reply With Quote
Old 03-07-2014, 09:28 AM   #8
Wrecked1982
Wrecked1982's Avatar
is castrol synchrotorque available in canada cheaper?
Wrecked1982 is offline   Reply With Quote
Old 03-07-2014, 10:45 AM   #9
whitedog76
I guess a 75-85 GL4 oils is what's recommended. Don't use GL5 oil, the additive package messes with the synchronizers and brass components.
http://www.allpar.com/mopar/transmissions/NV4500.html
whitedog76 is offline   Reply With Quote
Old 03-07-2014, 12:27 PM   #10
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
NV4500’s are a finicky transmission to begin with I personally won’t take chances with any oil other than the OEM oil even if it does cost a few bucks more per quart. I agree with the part numbers Ryanroo posted.
I do like the idea of added capacity though. We'll see how the coolers and added capacity workout in time.
DirtyLarry is offline   Reply With Quote
Old 03-07-2014, 05:10 PM   #11
Dieselwrencher
We've ran the coolers that are all aluminum and have had good luck with them. On 2nd gen dodges you can't run the LH side one though.
Ryan
Old 03-07-2014, 08:05 PM   #12
farmero
Well, I could not find any GM oil around here. I did find Amsoil synthetic. The label states that it is a direct replacement for GM part no.12346190. It has just a light oil color to it. I put four qts in for now. On my test drive it shifts very nice. It does have a slight werring noise when in motion. First time I ever looked at the inside of one of these. It has been a challenge. Thanks.
Old 03-07-2014, 11:13 PM   #13
95 S_Trucker
95 S_Trucker's Avatar
Outten, Quigley, Faulkner, and Kelly could have gotten the fluid for you. All are within 20 minutes of you.
You are right with the fluid level. The capacity is one gallon.
95 S_Trucker is offline   Reply With Quote
Old 03-07-2014, 11:17 PM   #14
95 S_Trucker
Synchromesh is for the nv1500, nv3500, and nv5600. It's about the same consistency as 5w30. It's not recommended in the nv4500.
Both gm and dodge use the synchromesh name.
Old 03-25-2014, 12:33 AM   #15
'63GENIII
'63GENIII's Avatar
I'm running the same stuff, no problems after approximately 8500 miles. Easy to get too.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
