Re: engine problems......help
Make sure that CTS (coolant temperature sensor ) is good and connected. In your original post you have described all classic conditions of disconnected (or bad) CTS. This is sensor is $15 and screws into intake manifold just in front of the thermostat housing.
Also check and see if ECM has set any trouble code - install jumper between terminals A&B of the ALDL connector and turn ignition on while observing SES light blinks. EFI trucks are much easier to diagnose. //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
| Bookmarks |
