03-10-2014, 12:20 PM | #1651 |
Grand PooBaa Member
Re: Kabwe's aka Bam's build
What is Slicksand?
03-10-2014, 12:25 PM | #1652 |
56 - autocross
And why you love it so much?
03-10-2014, 12:28 PM | #1653 |
Elev8r Man
Oh man, that firewall looks sweet.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!! 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
03-10-2014, 12:30 PM | #1654 |
http://www.eastwood.com/slick-sand-gallon.html
There, now Bam won't chime in and jump all over your ass - like he usually does!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
03-10-2014, 12:52 PM | #1655 |
Certified Car Nut
Slicksand is a polyester primer that goes on thick way thicker than 2k primer or even high fill primer. Its like spraying a nice thin coat of filler over a panel. Its really great for getting a panel straight. You block it and most of it will end up on the floor just like filler. There are other polyester primers out there I've used slicksand and pcl poly primer. I like slicksand a little better because it gets lighter as you sand it which is like having a guide coat built in.
It goes on top of epoxy primer and should not be used in place of epoxy primer which provides your corrosion protection. Its just a filler primer. Also thanks fabguy. Dan I only give Vdog dog a hard time because he is a buddy of mine. |
03-10-2014, 12:56 PM | #1656 |
56 - autocross
looks like I will use it as well. Thanks.
03-10-2014, 12:57 PM | #1657 |
Slicksand is proof that God loves us and wants to have laser-straight panels on our hotrods.
If you don't need quite as much fill, Featherfill G2 is the same stuff from the same people, just not quite as thick, and it lays down a wee bit better. Keep it up, Kab~!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
03-10-2014, 12:57 PM | #1658 |
Certified Car Nut
03-10-2014, 01:01 PM | #1659 | |
Certified Car Nut
03-10-2014, 01:03 PM | #1660 |
I also throw a splash (like you're mixing drinks) of lacquer thinner in it. Helps it move through a 1.8 tip, and lays out nicer.
Damn, I need a cannon with a 2.2 tip.
03-10-2014, 01:13 PM | #1661 | |
Certified Car Nut
Thinning it is cool, but I shoot it straight out the can no thinner used with a 2.2 tip and it lays down nice. Here is a shot of a fender in slick sand shot that way. The light spots is were I started sanding and you can see how it acts as a guide coat. I only use that build in guide coat for the first round of sanding after that I use the 3m dry guide coat. |
03-10-2014, 01:19 PM | #1662 |
That 3m dry guide is the bomb! I was tired of breaking nozzles (*^$#$^&*!) off new cans of SEM guide coat. Your work looks great.
This has been, "Moment with bodywork geeks." Now back to your regular programming.
03-10-2014, 01:35 PM | #1663 |
Certified Car Nut
You got that right dry guide coat is another product that I love. Its cool we've had the conversation because others may want to look into these products. There is another dry guide coat out there Mirka Dry Guide coat. I have not used it but I'd bet its basically the same thing and it may be a little cheaper. They sure make life easier.
03-10-2014, 03:09 PM | #1664 |
Hell, look in The Astronaut's f-100 thread in Alt. tinkerings. He makes his own dry rub from graphite or something for next to nothing. You think you're obsessive, go check that out. Boy got mad skillz with a Z!
I...can do that...but no. Too many years in production. I've said before, with just a little caution and knowing where to really concentrate, 80-85% of the work will have 95-98% of folks raving about your ride. That last 20 is the hardest and most backbreaking, to please those 2%. But those are the people whose opinions matter the most when you hear them. Plus wherever your personal level of satisfaction may lie. I've enjoyed the convo as well. Be well, and keep up the good work.
03-10-2014, 03:29 PM | #1665 |
Looking real nice Bam.
Kim |
03-10-2014, 03:34 PM | #1666 |
Does that ever look straight. How thick do you think the filler is when it is done?
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 |
03-10-2014, 03:53 PM | #1667 | |
Certified Car Nut
Oh I forget to mention another reason I like it so much, it sands really easy. Last edited by Kabwe; 03-10-2014 at 05:54 PM. |
03-10-2014, 04:55 PM | #1668 |
I'm still not getting much truck time lately I hope that changes soon.
Cool work men, well i got over 10 years working on mine
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair 99 S10 http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
03-10-2014, 10:06 PM | #1669 | |
As I tell guys I work with, if I didn't like you, I'd ignore you. It's the guys you like you give a hard time and they give it right back to you. Well, at least that's the way I do it. Others may think that's weird. Oh well!
03-10-2014, 10:17 PM | #1670 | |
I know SQUAT about body and fender work but I know how to do hard, repetitive work so I should be good for basic stuff like applying epoxy primer with a Harbor Freight gun and then sanding, and sanding, and sanding... The info about guide coat stuff is helpful too. Curious: what grit of sandpaper do you usually use on combo bare metal/filler before applying epoxy primer? Or do you put your filler OVER the epoxy primer? Seems like that question is controversial on some posts.
03-11-2014, 09:41 AM | #1671 | |
Certified Car Nut
Sanding grit? I use 80 grit on bare metal if I shooting epoxy or applying filler. Its a rough enough grit for the epoxy or filler to bond to. I know people who use 36 grit when applying filler I just don't see it as necessary. By the way I now do filler over epoxy no controversy there it just works better for me as a home builder. Last edited by Kabwe; 03-11-2014 at 11:34 AM. |
03-11-2014, 12:53 PM | #1672 | |
Grand PooBaa Member
Thanks Dan: You know I tend to be his punching bag for no apparent reason. LOL
03-11-2014, 12:57 PM | #1673 |
If it's been blasted, etch (really nice panels) or epoxy straight to metal after a wipedown. I mechanically strip with 80 on a da pad in a drill and a wire brush, then 80/150 on a DA to level out. Then filler after epoxying, scrub the work area with 80 for filler tooth. I knock filler down with 80 on a block. If I think it's good, I lightly scrub with 150 to knock the 80 tooth down then SS it. I lay a good spot coat over the bodywork area areas, then a medium coat over the whole thing. Then when it dries, 80 real quick over your worked areas, re-guide if good and 150 the whole panel. Then 1 medium coat with ss, and finish out on that coat. Yellow truck in my sig was done this way.
Sorry to butt in again, Kab.
03-11-2014, 01:47 PM | #1674 |
Certified Car Nut
03-11-2014, 04:20 PM | #1675 |
Grand PooBaa Member
Its hard for me to follow the bodywork thing. Filler primer, epoxy primer, 2k primer, primer sealer. All I would know to do is sand the body, shoot some primer on and and paint.
Way too advance for me. |
