Old 03-10-2014, 01:54 PM   #1
jks67ss396
vibrations?
Hey guys
Im trying to see if i have an issue with my 5.3/4l60 or not
this doesnt happen if the truck is in park and i just rev the engine, so i dont think its engine
When driving the truck, there seems to be a certain resonant frequency/rpm that i feel slightly through the dbw pedal when i get on it a little. its probably the whole truck, but i feel it more in the pedal instead of the carpeted floor.
its not so much of "uh oh, something is wrong" as more of a "hey this thing has some b@lls"
if i let off the gas, the slight vibration goes away, get back on it, it comes back.
but as i gain speed, it goes away
its a 2 piece driveshaft
Ive checked motor mounts, trans mounts, ujoint strap bolts, greased all ujoints, checked exhaust bolts (have those layered rubber isolator hanger straps)
trans fluid is new, new filter, correct fluid level, external cooler
is this something on trans? something with 2 piece shaft? normal?
i would expect this kinda vibration through a throttle rod connected big block or if i have a misadjusted throwout bearing on a mechanical clutch, but not a dbw 5.3
thoughts? or your own experiences?
thanks guys!
jks67ss396 is offline   Reply With Quote
Old 03-10-2014, 05:22 PM   #2
solidaxel
solidaxel's Avatar
Re: vibrations?
Originally Posted by jks67ss396 View Post
Hey guys
thanks guys!
Let me know when you find and fix it !!!
I have the "same" vibrations while driving, everything checks out OK, but I am still looking for the source.
I have a 1 piece DS and this come in at 1250 to 1350 RPM and is throttle controlled ,in and out, at around those RPM's
New exhaust twice pipes with a crossover and very conservative Walker Muffs
This is a new problem as I have had this truck for 30+ years and it was not there before the swap.
Thanks for bringing this up!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-10-2014, 05:31 PM   #3
truckdude239
truckdude239's Avatar
Re: vibrations?
where your drive shafts balanced properly? i ahd mine shorthen twice by the same shop and they didn't balance it the second shop that shorted it becasue the frist guy couldn't get it right did balance it
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-10-2014, 06:19 PM   #4
jks67ss396
Re: vibrations?
Can you tell me about your setup?
5.3/6.0?
4L60 or 4L80?
What year motor?
DBW, right?
thanks!
Old 03-10-2014, 06:21 PM   #5
solidaxel
solidaxel's Avatar
Re: vibrations?
Mine is the same driveshaft no changes, the U joints are about 2 years old, did not make this vibes before the swap
LS 3 4L70E
Old 03-10-2014, 06:27 PM   #6
solidaxel
solidaxel's Avatar
Re: vibrations?
2003 5.3, 4L60E, DBW, all stock, except for the tune.
I loosened up the exhaust and drove it but that did not change anything.
The mounts are DirtyDingo with new rubber, stock stands and they are tight, rear trans mount is new also, X member is moved to the rear 1 3/4 " no other changes and nothing than I can see is rubbing on the chassis.
I had the dog house removed and I did not have any interference with the firewall
LS 3 4L70E
Old 03-10-2014, 06:42 PM   #7
jks67ss396
Re: vibrations?
ok, so if its not driveshaft, and i dont think its engine (since it only does it when its moving), then im thinking 4l60. be interested to see if a 4l80 would do same thing
Ill see if my vibrations are at the same rpm range yours are.
have you ever taken it to aamco or something for a free diagnosis?
thanks
Old 03-10-2014, 06:43 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: vibrations?
What are your pinion angles?
If you don't know....then its probably the problem
My old bagged minitruck used to love to rumble at various heights, because raising and lowering the truck changed the pinion angle.
When you do a swap, depending on the engine and tranny xmember position, and length of the DS, you can end up with a WAY different pinion angle than what you started with. This will wear out ujoints, and in a high hp application can be a huge annoyance.
Does the 2 piece shaft use a carrier bearing?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-10-2014, 06:51 PM   #9
jks67ss396
Re: vibrations?
ill check them tonight/tomorrow. everything on mine is stock suspension. rebuilt and new
i spent a lot of time doing this on my camaro, but with the truck, everything just kinda lined up and didnt look too bad but its worth checking
thanks
Old 03-10-2014, 10:41 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: vibrations?
I doubt you can eyeball your pinion angle, but it would be an impressive skill. It's usually a tad forgiving since the 2piece shaft takes up some of the flexion, but its worth looking at. Changing a u joint on the side of the road is a pain.
Old 03-16-2014, 11:43 PM   #11
solidaxel
solidaxel's Avatar
Re: vibrations?
I checked mine and it is 3* down at the trans and 2* up at the rear end.
Replaced the rear trans mount, and that did not change anything except my wallet is lighter!
LS 3 4L70E
Old 03-17-2014, 12:13 AM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: vibrations?
you can change the rear end angle, leave the trans 3* down (meaning the engine is also 3* down, which is good)
Old 03-17-2014, 12:16 AM   #13
jks67ss396
Re: vibrations?
i originally did mine like a one piece shaft. thats what i meant by not being too bad. turns out 2 piece shafts require a different procedure. i found a link on this forum to a dana article and checked mine. mine was about 4 degrees off at the rear and 1 degree off at the trans. so i shimmed up the trans and got the front in spec. i ordered some shims from stock car products and they should be here in a couple days.
ill report back when i get them put in
solidaxel... did the rpm of the vibration change after your trans mount swap?
Old 03-17-2014, 12:25 AM   #14
solidaxel
solidaxel's Avatar
Re: vibrations?
Just in my wallet!
My vibration is not in my driveline, when you shift out of gear at speed it goes away.
I can make it vibrate at 1300 rpm sitting still !!
Has to be the engine hitting somewhere, still looking for the cause
LS 3 4L70E
Old 03-17-2014, 12:35 AM   #15
jks67ss396
Re: vibrations?
ok, see, i dont think mine does it in park. ill check from idle to 2500 tomorrow
did you buy the engine/trans together? ever had them apart from each other?
if you can shift out of gear and make it go away, its gotta be trans, right?
Old 03-17-2014, 01:45 AM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: vibrations?
Just in my wallet!
flywheel bolt? its a beatch but it happens, especially tho those who had to put the trans on IN the truck.
Old 03-17-2014, 08:34 AM   #17
solidaxel
solidaxel's Avatar
Re: vibrations?
The engine was a take out from a Silverado complete package 72K.
Yes, I have experienced a cracked flex plate, I had not thought of that.
The vibration is not that bad just a certain RPM and tiney!
LS 3 4L70E
Old 03-22-2014, 03:40 PM   #18
jks67ss396
Re: vibrations?
well, i installed my pinion shims today and took it for a test drive.
the vibration is still there. around 1700rpm. again, its not bad, just noticeable. by 1900 rpm, its gone.
it is not there when the truck is in neutral.
im thinking of having the driveshaft shop take a look at it. they just cut the shaft and balanced it before the swap
any other ideas?
Old 03-25-2014, 12:53 AM   #19
jks67ss396
Re: vibrations?
So ive tracked my vibration down to something in the vintage air/kwik performance install. decided to take off the ac compressor and brackets and put the stock tensioner back on, vibration gone. Put the brackets and compressor back on, vibration comes back. compressor is not charged, just spinning freely with the engine.
im thinking tensioner or this idler pulley that comes on the kwik setup
any of you guys have experiences like this?
thanks
Old 03-25-2014, 08:33 PM   #20
69sinker
69sinker's Avatar
Re: vibrations?
Glad you found the problem, but I hate to hear that's what it was. I'm putting on the same setup this weekend. I'll let you know my results. How long has it been on there? Dave
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build
http://67-72chevytrucks.com/vboard/s...d.php?t=589869
69sinker is offline   Reply With Quote
Old 03-25-2014, 09:04 PM   #21
jks67ss396
Re: vibrations?
well, my story starts with the fact that the camaro tensioner that kwik specified stuck out way too far. this was a delco part. so wayne sent me a corvette tensioner and spacers. i did find a belt that works. napa 113" made by gates.
but the vibrations are annoying.
I talked with a dayco tech today about resonant freqs and how changing belt length between pulleys/tensioners etc can change freqs.
Ive ordered a shorter belt and im going to pull the top idler pulley off and run without it. hopefully the longer belt span from alternator idler to compressor will change the resonant freq of the system to something a little lower.
with a 373 and my tires, 1600 is right at 55 in 4th gear.
ill post results here.
