03-09-2014, 08:10 PM | #326 |
RAT1968 '68 Cab/'71 Parts
Re: What did you do to your truck today? Chapter II
Here ya go:
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
03-09-2014, 08:11 PM | #327 |
03-09-2014, 08:16 PM | #328 |
New fan belt and new battery...
1970 SWB "old flame" 1967 SWB c10 sold 1972 Elcamino 496 2012 Denali HD dmax |
03-09-2014, 09:41 PM | #329 |
Taped my bed to cut the back 8 off tomorrow! Measured 100 times to cut once hope it goes good
03-09-2014, 10:55 PM | #330 |
Fixed the tranny pan gasket on the new 68. thought it would be an easy gasket but once i pulled the pan i found one corner was dented up so i banged it back out straight. Then put the new gasket in and buttoned it up turns out the PO had striped out 2 of the bolt holes so i fixed those too. No more tranny leaks! Replaced some bulbs in the cab lights. Topped off all the fluids. Tomorrow ill powerwash all the gunk off the underside and start figuring out wiring some lights, some gauges, radio antenna etc... Never ends!
03-09-2014, 11:57 PM | #331 |
tcoop68
Started my new engine in my 72 S/W runs great.
03-10-2014, 12:11 AM | #332 |
tcoop68
03-10-2014, 02:21 AM | #333 |
Ridgeclimber dash looks sweet.that's something I had imagined, nice to see art brought to life. I like the digital readout too. Sic68 that's one clean interior,very nice!
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
03-10-2014, 04:23 PM | #334 |
pulled the complete sway bar assembly from the 67, and transplanted it to the 69. the ole behemoth has much better manners, but shes still a lil tipsy. i learned something important... cutoff wheel + angle grinder + BFH & punch = Rivet-B-Gone!
'69 c10 longbed granny 4spd 292 "Behemoth" '67 c10 longbed granny 4spd 292 "Burzum" some pictures of my work in progresshttp://photobucket.com/zaeea R.I.P. Corey "Flattus Maximus" Smoot 11/3/11 You will be missed. Your sound lives on. |
03-10-2014, 04:35 PM | #335 |
I just bought this 5 days ago!!! Its been garaged for a few years. So I emptied the gas, clean the carb, changed the oils, filters, rotor, distributor cap, plugs and wires, battery. My First Toy!
03-10-2014, 04:38 PM | #336 |
03-10-2014, 04:44 PM | #337 |
C20 454 big block with 38k No rust always garaged! Found it in Oregon for only $6500!!!! |
03-10-2014, 04:51 PM | #338 |
WOW!!!!.. What a STEAL!!!
03-10-2014, 04:59 PM | #339 |
03-10-2014, 05:03 PM | #340 |
Nah... I have my Money pit sitting in the garage... LOL
03-10-2014, 06:01 PM | #341 |
I've been playing with the ZZ4 block for a couple of days.
From the numbers (and from looking), I found out it is a standard bore (350) 87-95 four bolt, one piece oil seal, roller cam block. No crank or rods or pistons, so it'll be a big $$$$ to get it to a 383. Next up, the 350 flat-tappet, two-piece, four bolt block from Tom. No usable rotating assembly on that one, either. But that looks like it wants to be a mild 350. One of these days, I'll figure out where to start. At least I have the 062 heads all done that'll work on either build. For right now, it's clean up the blocks and gather data.
03-10-2014, 07:21 PM | #342 |
03-11-2014, 03:02 AM | #343 |
Got my fuel lines replaced, vac lines hooked up, cap and wires installed, oil changed, charged battery in, and it runs! Kinda. Need to tweak the timing and carb adjustment, but it is progress.
Hope to have more things done this week.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast! Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun. 1st BN 3rd MAR. '00-'04 |
03-11-2014, 03:27 AM | #344 |
New 3" stainless exhaust.
I guess sending the boy to welding school has paid off. |
03-11-2014, 09:26 AM | #345 |
It is from a late 80s early 90s Chevy. Had the headrests removed and seats recovered.
70 SWB 454/TH400 |
03-11-2014, 09:59 AM | #346 |
Quick Question. I recently started a new build on a 68 c20 Custom Camper. Internals and functionality is flawless but the body leaves something to be desired. Indiana truck...what can ya do?
I have an opportunity to purchase a good looking parts truck very close to home. 69 c20. The price is right. Will all of the body pieces fit my 68 c20 custom camper frame? Doors, hood, front and rear fenders, bumpers, bed, etc? I am a beginner and really don't have the capability of pulling the motor, otherwise, I would obviously do the opposite and just transplant the organs. Any advice you have would be much appreciated. Thanks |
03-11-2014, 03:24 PM | #347 | |
03-12-2014, 10:34 AM | #348 |
Birthday was Monday.all I asked for was to have the garage for a day. Buddy came over to help. Perfect day IMO. Changed out core plugs a.k.a. freeze plugs. Of course the one that gave me the most trouble was the one that actually needed replacing! Lol. Flushed out coolant jackets, had about an inch of fine sediment all around block.picked up this sweet chromed aluminum water pump. Birthday present to myself.My other buddy came by yesterday and dropped of his hoist. I was hoping to install today,but its pretty windy outside. At least I won't have to rake leaves for a while!
03-12-2014, 05:22 PM | #349 |
Finally finished the Autowire complete rewire on my truck,put on a new alternator, and broke the hood hinge!!! what the heck
03-12-2014, 05:59 PM | #350 |
After 6 weeks at the machine shop, I finally got my block back today. Thoroughly cleaned and taped off... Now priming!
