Re: 6 Lug disc brake using 88-98 spindles ?????
I think if you machined an 1/8" off the upper arm cross shaft surface that would buy you .5 but an 1/8" seems like a lot to me to take off. Just throwing ideas out there. You'd probably have to clearance the backside of the upper arm so it doesn't contact the frame too.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
