#17 | |
Re: Servicing the rear end hubs on a dually
Glad I checked this 1st. My 2nd choice was to disassemble/remove the hubs from the rear end & swap them side-to-side to see if the issue followed the drum/hub or stayed on the drivers side. Much less work ![]()
