Old 03-11-2014, 10:05 PM   #1
GoaterAz
GoaterAz's Avatar
Simple Question - Reverse Light Housing
Is there a trick to remove the wiring from the reverse light housing?
I've spun it around and pulled on it with no luck, I don't want to ruin anything.
Thanks for any direction…
You remember when drinking too many beers was a bad idea?
Me neither.
GoaterAz is offline   Reply With Quote
Old 03-11-2014, 10:30 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Simple Question - Reverse Light Housing
It has to come out through the front but I don't remember if there is a trick to it or not. I will be removing a couple of the assy's tomorrow and I will take a look if you don't get a reply before then.
LockDoc
Leon
Old 03-12-2014, 10:35 AM   #3
GoaterAz
GoaterAz's Avatar
LockDoc
I would appreciate that, Thank you.
Any other input is also welcome.
Me neither.
Old 03-12-2014, 01:45 PM   #4
jfd3604
jfd3604's Avatar
Push it out the front just did it a couple of weeks ago. Are you having a lighting problem? The housing has to ground to work.
1971 C-10 Short Bed
jfd3604 is offline   Reply With Quote
Old 03-12-2014, 06:15 PM   #5
GoaterAz
GoaterAz's Avatar
Good Information, Thank you.
I'm not having any lighting problems, just unpluging the wiring for a bed removal down the road.
I will mess with it tonight and you keep you posted, but thinking about it, I'm not sure how I would get the housing off the truck if I pushed the wire though the front? If that any makes sense.
Me neither.
Old 03-12-2014, 06:19 PM   #6
LockDoc
LockDoc's Avatar
There is a connector down inside the wire channel. You just unplug it. You don't have to take the bucket apart.
LockDoc
Leon
Old 03-12-2014, 10:24 PM   #7
GoaterAz
GoaterAz's Avatar
LockDoc
Man, I owe you another beer…these are adding up, lol.
I would have never found that booger, you can't really see it, let alone disconnect it from under the truck and when I pulled the housing out, I wasn't looking in that window behind the brake light assembly. Thank you!
Here are a couple pictures for future searches:
Me neither.
Old 03-12-2014, 10:28 PM   #8
LockDoc
LockDoc's Avatar
I may be down to collect one of these days..... Anyways, glad you got them out with no damage...
LockDoc
Leon
Old 03-12-2014, 10:30 PM   #9
BrianG
BrianG's Avatar
I'll have to buy him one too then! I was actually planning on posting the exact same question. Thanks guys!!! Gotta love this board!
BrianG is offline   Reply With Quote
Old 03-12-2014, 11:01 PM   #10
jabborabbo
jabborabbo's Avatar
I already owe Leon at least a six-
pack...or maybe a fifth of bourbon, depending on his preference....
jabborabbo is offline   Reply With Quote
