Old 03-13-2014, 12:55 AM   #1
Blakeman350
Blakeman350's Avatar
305 v6 questions
Does anyone know if the carb and water pump on a 305 v6 are engine specific or if other engines ran those same parts. The carb is a 2 barrel and I'm trying to find a rebuild kit for it and the water pumps broke. Any help would be greatly appreciated.
Blakeman350 is offline   Reply With Quote
Old 03-13-2014, 01:51 AM   #2
airdale94
airdale94's Avatar
Re: 305 v6 questions
You'll need the numbers off your carb. to get a kit for it. I don't know what kind of carbs. they ran on those things, but I would think most any 2 barrell would bolt on to your intake if you can't find a kit. I would think the water pump would be GMC 305 V-6 eng. speciffic, but I could be wrong. You'll just have to have a parts guy look it up. You could punch it in to O'Reily's or RockAuto.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 03-13-2014, 02:39 AM   #3
Blakeman350
Thanks for the help airdale, I think I'm going the right direction now.
Old 03-13-2014, 10:16 AM   #4
DreamRyder1963
DreamRyder1963's Avatar
I got the water pump for my brother's 305e from rock auto. It was a perfect match. Be careful when going to your local auto parts. I work for Advance Auto and our computer often confuses the 305 V6 with a sbc. Don't be afraid to get parts from your flaps but you might want to go in and ask if anyone has experience with old GM products.
1971 Chevy C10 Cheyenne (sold for Mazda)
1963 Chevy Corvair Pro-Touring Project
2012 Mazda 3 i Sport sedan
http://www.dracoautodesigns.com/
DreamRyder1963 is offline   Reply With Quote
Old 03-13-2014, 11:28 PM   #5
Bob B.
The water pumps are still available no problem. The larger V-6's used a water pump with a threaded shaft, just be sure you get the one with the flange for the pulley. The original carburetor should be a Stromberg WW. Those are pretty rare, but a Rochester 2 bbl. off a older small block Chevy would probably work O.K..
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
