03-08-2014, 02:20 PM | #1 |
Active Member
WTB 69-71 blazer filler neck and tank
I am looking to put a second tank in my 1970 c10 using 1969 to 1971 blazer parts.
Please send info on any of the parts you have to sell. Thanks Joe |
03-08-2014, 02:29 PM | #2 |
Re: WTB 69-71 blazer filler neck and tank
Is the 1972 diffrent then. 69 - 71 and is there a diffrence with 2 wheel or 4 wheel drive.
03-08-2014, 03:39 PM | #3 |
Active Member
The 1972 has a solid steel filler neck all the way to tank, the others have a fill neck then a hose section and then steel below the bed towards tank. The gas cap is also a different size.
I am not sure if there is a difference between 2WD and 4 WD Thanks Joe |
03-08-2014, 03:53 PM | #4 |
Borrowed from other threads:
These are from 1972 Blazers. Hope this helps. Also available from another member are some nice kits at http://gmcpauls.com/fuel_tank_&_related.htm
1971 Bone Stock C10 project "Jake" 1997 Sierra SLT factory short bed "Silver Bullet" Last edited by Jake1971; 03-08-2014 at 03:59 PM. |
03-08-2014, 10:01 PM | #5 |
Active Member
Thanks for the pictures.
Is the pipe next to the fill neck in the blazer picture part of the fuel system? Joe |
03-09-2014, 12:55 AM | #6 |
Location: Fort Mitchell, AL (out the back gate of Ft Benning)
Vent tube
SSG Walker Harris '72 Cheyenne Longbed '66 Panel '66 Short Stepside '65 Short Fleetside |
03-09-2014, 01:57 AM | #7 |
Active Member
Thank you
03-10-2014, 10:31 PM | #8 |
I have a tank shipped from nm its a poly tank
03-10-2014, 10:39 PM | #9 |
Active Member
Thank you but I a looking for a metal tank.
Do you have any other Blazer fuel pieces like fill neck or lower filler pipe? Joe |
03-11-2014, 08:59 PM | #10 |
I have a 71 setup with filler tube, bottom elbow, gasket w/ plate, and cover. I sandblasted the bottom elbow because it was pretty rusty and blew a hole thru it. I had a guy at work tig weld it with what he called silicone bronze wire and pressure tested it to 15 psi. I have a photo of the repair. The cover has the one corner rusted off I included a picture of the other side to compare. 100 shipped for everything. I have a tank also w/ sending unit that was on my blazer when I 4wheeled it so it has dents in the bottom but no holes. Let me know if interested and I will figure out a price. Sending unit worked when I pulled it out but that was 6 + years ago and two moves.
03-11-2014, 09:01 PM | #11 |
forgot pictures
03-11-2014, 09:33 PM | #12 |
Active Member
Hello
Yes interested in the items pictured and also the tank and does it have the tank straps? Do you have fuel vent tube? Thanks Joe |
03-11-2014, 09:48 PM | #13 |
I have straps will they work for what you are doing? 100 dollars for the tank that will be 200 for everything plus shipping.
03-11-2014, 10:09 PM | #14 |
Active Member
The factory tank is supposed to fit with the factory straps
is it possible to send picture Thanks Joe |
03-11-2014, 10:10 PM | #15 |
Yep will send tomorrow
03-11-2014, 10:17 PM | #16 |
Active Member
Do have vent tube?
03-11-2014, 10:32 PM | #17 |
Sorry forgot to respond the first time you asked unfortunately I do not. I do not even have one for my build.
03-11-2014, 10:35 PM | #18 |
I may have a friend that has one I will ask him tomorrow
03-12-2014, 06:59 PM | #19 |
My friend does not have a vent tube attached pics of the gas tank, straps, and spacer between the tank and frame(I am guessing you will need this). Something else I could probably meet you in Winchester if that would work for you
03-12-2014, 09:37 PM | #20 |
03-13-2014, 11:20 AM | #21 |
Active Member
Winchester will work great
how is the filler neck on the tank, any damage? |
03-13-2014, 12:00 PM | #22 |
No i can get better pictures if you like the edge might have a ding in it but nothing major. If you want to meet in Winchester I have a second tank I will bring them both and you can have you pick same condition. PM sent
