#11 | |
Re: Crusty Rusty Leaky Squeaky 67 Step
Every body guy i talked to said to stay away from sharp corners, most said if you have a square door then cut the filler square then radius the corners, if the door is round then cut the flange round, just passing along, i'm sure you have it covered tho cause your work has been outstanding.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
| Bookmarks |
