Old 12-30-2003, 12:02 AM   #1
roy
what body styles will work?
i have a 1972 lwb, 4x4, chev p/u rolling chassis. What range of years of bodys will bolt right up to existing body mount brackets and will a 2wd body fit on the frame?
roy is offline   Reply With Quote
Old 12-30-2003, 12:07 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Cabs should be the same, from 67-72. You'll have to use the bed that fits your frame. I think the only real difference you'll find between 2WD and 4WD cabs is the hump on the floor. I believe that 4WD cabs have the taller hump. Some 2WD cabs do, too.
Member Nr. 2770
Old 12-30-2003, 12:08 AM   #3
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
A two wheel body might fit, but you have to fabricate a 4x4 center hump into the floor. Because the 4x4's transfer case.
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 12-30-2003, 12:10 AM   #4
724x4a/cchevy
a two wheel drive with a standard transmission would work, because the standard cabs have high humps in both 2 and 4 wd models
My LED Website
I also do LED:
-Third Brake/Cargo
Norwood Survivor
Old 12-30-2003, 12:32 AM   #5
Randy70C-10
Randy70C-10's Avatar
My cab has a low hump and came with a standard tranny. The shifter was on the tree, are they different?
Randy70C-10 is offline   Reply With Quote
Old 12-30-2003, 12:37 AM   #6
Steven Sellers
Steven Sellers's Avatar
Low hump 3 on the tree here also
2008 Buick Enclave(wifes new non wrecked)
1996 Jeep Cherokee
2002 2500HD 6.0L (traded)
1998 Jeep Grand Cherokee(wifes/wrecked)
1977 DJ5 postal jeep(mmm lots of fun)
1988 Toyota 2wd p/u(DD, blewup 199,000)
1991 Toyota 2ed p/u (sry just cant break these things)
1997 XR70 Honda
1991 Z50(FOR SALE)
1972 Z50 Honda
1970 SWB 350/knucklebuster "The adventure begins and I am confident that there will be no end".
Steven Sellers is offline   Reply With Quote
Old 12-30-2003, 12:47 AM   #7
Blue_71
Bloo
Blue_71's Avatar
3 speed cabs are low hump, TH400 cabs are high hump, 4 speed cabs are high hump, 4x4 cabs are high hump, auto cabs are low hump
i have a bed from a 2wd coil truck on my K20, so those interchange, and the front clips all interchange, and the cabs do other then slight differences but they will bolt up
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 12-30-2003, 01:19 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Blue...not so on the TH400 cabs...they would be low hump if in a 2 wheel drive with a small block.
The only thing you may have to worry about, would be the possability of nooeding to cut out the low hump, and installing a high hump, and if the cab came from a 2 wheel drive 1/2 ton, then you'd need the other style rubber cab mounts. (1/2 ton 2 wheel drive used one style mount...all others used the other style mount.)
Old 12-30-2003, 04:26 AM   #9
dinnut
dinnut's Avatar
btw... welcome to the board!
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-30-2003, 08:21 AM   #10
krue
Designated A-hole!
krue's Avatar
What they said, and welcome to the board from soggy South Mississippi!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
