Old 12-28-2003, 08:08 PM   #1
ROAD DOG
Top of the foodchain
4.56 or 4.11 gears?
I'm about to change my gear ratio. I had been thinking 4.56 gears.. But now I'm debating on 4.11 gears. The truck is a 1970 K-10 with a built 355. sm465 4 speed tranny with stock 3.07 type 3 carrier gears. Running on 31" MT tires.
The calculator says
3.07@65mph = 2163rpm
4.11@65mph = 2896rpm
4.56@65mph = 3213rpm
My cam doesn't make serios power till around 2400 rpm
But after that its 400+torque monster. Right now its a pig off the line. You get to 75mph on the freeway@2500 rpm and you could pass any car on the road. I just want to know if 4.56 is too much or just enough. I go 4 wheeling quit a bit but want a ratio I can drive 70mph to get there.thanks.
1970 K-10 4x4
1975 Jeep CJ-5 4x4
1990 Jeep XJ 4x4
Smell the Magic!
ROAD DOG is offline   Reply With Quote
Old 12-28-2003, 08:15 PM   #2
Destructo
I wouldn't run gears that are going to put your cruise rpm above 3k. I would like something right around 2500 rpm cruise.
Destructo is offline   Reply With Quote
Old 12-28-2003, 08:50 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yeah, my 4:10 (4:11?) gears are fine on 2-lanes with 55 mph limit, but at freeway speeds, it's as low as I'd want - I think you'd regret 4:56s.
BTW that's with 33-12.50/16.5s, about 32.3" tall.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-28-2003, 09:25 PM   #4
Destructo
I'm planning on running 35" tires and using 4.56 gears, but I also have OD so i'll only be turning about 2000 at 65mph.
Old 12-28-2003, 10:50 PM   #5
kwmech
If you are going to do serious towing I would look at the 4.10s if not I would run a 3.73 with the 31'' tire. OR you can buy the 4.56s and then call me and purchase an NV4500 and matching t-case I have for sale
Old 12-29-2003, 12:30 AM   #6
ROAD DOG
Yep it's looking like 4.11's. I havent done a rear gear change before,I wonder how the truck will act with 4.11's.
Up from the stock 3.07 I'm expecting alot.
1970 K-10 4x4
1975 Jeep CJ-5 4x4
1990 Jeep XJ 4x4
Smell the Magic!
Old 12-29-2003, 12:33 AM   #7
rogf4
I hope your motor has a serious bottom end if you decide to go with the 4.56 gears without over drive
rogf4 is offline   Reply With Quote
Old 12-29-2003, 01:19 AM   #8
earl87gta
earl87gta's Avatar
You may be agle to find a good set of axles with 4:10 in them cheaper then changing gears you may want to look in to guy a complete set of axles I sold a the d44 and 12bolt out my blazer for 250 with 4:10s in it when I whent to D60 and 14b. Im running 4:10 in the new set up with 36 in tires, my old tow rige had 4:56 with 31in tires and it was horible if you had to drive it over 55.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 12-30-2003, 02:11 AM   #9
ROAD DOG
Good feed back on this post, right on!
I've been looking through salvage yards, junk yards and old farmers backyards here in denver metro. for a couple of months. And haven't found nothing more then 3.73's. From spining tires counting driveshaft revolutions, to pulling covers counting teeth,
You'all know the deal. nothin,
On the parts board a guy from washington that has both axles with 4.10's for $200 obo!!!!!! If he was within 500 miles they would be mine!
Anyways I just dropped $290.35 to Summit for richmond 4.10's and install kit for the rear. What sucks is I'll have a two wheel drive truck until I save the dough for the front.
1970 K-10 4x4
1975 Jeep CJ-5 4x4
1990 Jeep XJ 4x4
Smell the Magic!
