Lwb cross sills (help!)
Well it's getting late here I don't wanna leave a job half finished so here's the big question on the longbed there should be 5 large cross sills and I only see enough bolt holes for 4 and I guess the small support sill. Where is this goth cross sill near the rear supposed to be they are the number 3 sills according to the lmc catalog but give no further help. If I had my computer not accross the city I would research it but if I could get some quick help?
1968 Chevy C10 build - http://67-72chevytrucks.com/vboard/s...d.php?t=546713 Member of tailgate association of manitoba |
#2 | |
The Older Generation
Re: Lwb cross sills (help!)
Wood bed floor or steel? LockDoc
Wood bed it's a 1968
There are some pictures in this thread.... http://67-72chevytrucks.com/vboard/s....php?p=6410882 Not sure how much it will help. LockDoc
Looks like the rear most is free floating. I am making these cros sills from scratc so you can see why I am gonna need all the help I can get :/
Rusty Nuts
Maybe this will help for locations.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
Do you have in relation to the frame?
![]() Join Date: May 2010
Try this link.
http://67-72chevytrucks.com/vboard/s...d.php?t=581185 And... from Mar-K "The first cross sill connects to the second bed strip hole that is 3-3/8 inches back from the front of the bed. The second cross sill connects to the third bed strip hole that is 15-3/8 inches back from the front. The third cross sill attaches to the bed strip hole 26-3/4 inches from the front of the bed. The fourth cross sill connects to the eighth bed strip hole at 72-1/2 inches from the front, which coincides with the rear of the wheel well. The fifth cross sill connects to the ninth bed strip hole at 83 inches from the front. There are two smaller cross members located at the front or beginning of the wheel well and at 60-1/8 inches from the front of the bed. One reinforcement strip is 72” and one is 49-1/2”. Attach these reinforcement strips to the bolts from the bed sides and the wheel well. Mount the 72” at the front of the wheel well and the 49-1/2” reinforcement strip fits between the wheelhouses at 60-1/8 inches." Last edited by FirstOwner69; 03-16-2014 at 02:53 AM. |
#10 | |
Thanks! Just what I needed to know.
1968 LWB C20 / AC / Wood Bed |
kind of since youve been through this recently i believe its these two sills no sure if they are bolted to the frame being there are no holes i will have pictures of my project on my build thread shortly.
I did not realize there are 2 reinforcement strips, i circled the 2 i need info on so ill continue to research and look things up but it doesnt look like i have a second set of holes on the rear end for another rear sill.
There is only one reinforcement strip shown in the picture of mine above that you copied from the other thread. My truck never had the 2nd one that Mar-K said I should have had. The only cross sills that get bolted to the frame are those at 3-3/8" (1st), 26-3/4" (3rd), and 72-1/2" (4th) from the front. The rear cross sill bolted and welded to the bed sides also gets bolted to the frame through the brackets welded to it. As I recall, the other cross sills (2nd and 5th) and reinforcement strips are only bolted to the metal bed strips and just rest on the frame.
Here is a picture of mine taken at a slightly different angle that better shows the sill and reinforcement strip depths. Last edited by FirstOwner69; 03-16-2014 at 04:20 AM. |
#15 |
Diging this up... it looks like there should be a short cross brace going between the wheel wells, otherwise there's a large unsupported area between the 2nd to read cross brace and the high spot on the frame with rivited crossmember.
Was there a brace here from factory and if so, where? I don't see it listed in my catalogs.
#16 |
I found at mar-k "67-72 Fleetside Bed 49.5" Reinforcement Cross Sill With Wood Floor" and I guess this goes at the mid-point of the tubs but I haven't been able to find any pictures to confirm this. There are no frame holes for it so I guess it must just float like the other reinforcing strip?
#17 |
... anybody know? Still haven't been able to find an answer anywhere.
