Old 03-16-2014, 01:11 PM   #1
yossarian19
Advice for first-time exhaust builder?
I'm getting ready to place my order for exhaust parts from Summit.
Any special tools or general advice that will make life easier when I get ready to start putting the pieces together?
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 03-16-2014, 01:26 PM   #2
vidman
vidman's Avatar
Re: Advice for first-time exhaust builder?
Are you clamping or welding it together..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 03-16-2014, 01:41 PM   #3
BlueJeep
BlueJeep's Avatar
However many U-bends you think you need, add at least one more. I cut my pieces in a band saw and then sand until it's a perfect fit. I found that I didn't need nearly as much straight tube as I had ordered because of the "legs" of the U-bends. Start from the manifolds and work your way back, tack pieces together so you don't have as many that you're juggling.
Have fun, and enjoy that you're not paying for kink bends and routing that's not quite what you wanted.
Oh, and since you mentioned Summit don't bother buying the band clamps with the holes in them for tack welding. Those only work if you're connecting two straight pieces.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 03-16-2014, 01:43 PM   #4
_Ogre
_Ogre's Avatar
a abrasive chop saw is great for cutting tube and bends, that said i did my whole exhaust system with a 5 inch cutoff wheel in a 4 inch grinder. i also used my flux core welder to weld up truk.
use tape or a string to mark your cuts. masking tape to hold the bends in place for checking fit.
buy the bends and start cutting
shop air compressor timer
Old 03-16-2014, 01:54 PM   #5
yossarian19
I'm planning to weld it all. I'd like to get parts to slip fit so I have the option of clamping if needed & to take some of the pressure off on my welding (I'm still novice)
Thanks for the tip about skipping the band clamp.
I'll probably do all my cutting in a bench vise with a 7" cutoff wheel. I'd much prefer a 14" chop saw or a band saw but we'll see. I don't know that I've got the pocket cash to buy another big tool just now.
"Over my head"
Old 03-16-2014, 02:16 PM   #6
Stepside Jim
Just as Bluejeep has in his pictures......tack weld, don't do any full welds til all is together and fitted.
I also end up measuring then I cut short of my mark, what I mean is...I leave a little extra material after the cut, I figure I can always trim some easier than adding some.
Here's the left over trimmings after my last exhaust build.
Good luck, Jim
Stepside Jim is offline   Reply With Quote
Old 03-16-2014, 06:23 PM   #7
Indian113
Indian113's Avatar
Check out the 2 1/2 inch exhaust kit in Speedway's catalog it's $139.99 it's also set up for slip fitting. I'm going to order it I think I can do my Model A and then buy pieces to do my 64 C10 with the leftovers.
Indian113 is offline   Reply With Quote
