Old 03-06-2014, 11:10 AM   #1
ScottH
ScottH's Avatar
67-68 sbc alternator brackets
Selling a pair of correct 67-68 only sbc alternator brackets in good shape.
Asking $35 shipped in conus.
Scott
1960 Apache stepside (project)
1966 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. 210 wagon
ScottH is offline   Reply With Quote
Old 03-08-2014, 10:59 AM   #2
ScottH
ScottH's Avatar
Re: 67-68 sbc alternator brackets
bump
Old 03-13-2014, 11:23 AM   #3
ScottH
ScottH's Avatar
ttt
Old 03-16-2014, 02:03 PM   #4
65 C20
What makes the 67-68 different.
Does the adjuster bracket use an intake bolt to mount it.
Cal.
65 C20 is offline   Reply With Quote
Old 03-17-2014, 12:15 AM   #5
ScottH
ScottH's Avatar
For some reason they had different mounting brackets for those 2 yrs.
Yes, pretty sure the upper bracket bolted to the intake.
Old 03-18-2014, 01:18 PM   #6
65 C20
Hi Scott, I am interested in the brackets if you can take some meaurements for me.
If you lay the flat part of the adjustment part on a flat surface what is the offset to the centerline of intake mounting bolt ? approx. 2 1/4" ?
Also what is the measurement from center of mounting bolt to to the farthest spot that you can adjust ? Measure in a straight line. Approx. 13" ?
This will be going on a 65 with a short water pump and Weiand intake that is not drilled and tapped to mount to front of intake as normal.
Thanks Cal.
Old 03-18-2014, 06:24 PM   #7
ScottH
ScottH's Avatar
Cal, offset appears to be about 1 1/2" (bracket has a curve in it), and the 2nd measurement is 12".
Scott
Old 03-18-2014, 10:59 PM   #8
65 C20
Scott
Scott, Not quite sure if this will work for me.
Could you take 1 more measurment for me ?
If you put the intake mounting bolt hole and lay it flat on the table, how far off the tabel is the farthest most adjustment point off the table.
Hope this makes sense. And sorry for so many questions, just don't want to buy if it won't work.
Cal.
Old 03-18-2014, 11:59 PM   #9
ScottH
ScottH's Avatar
No problem at all Cal, understand completely.
Will check tomorrow & let u know.
Scott
Old 03-19-2014, 04:03 PM   #10
ScottH
ScottH's Avatar
Cal, let me know if this is what u need.
Scott
Old 03-19-2014, 10:17 PM   #11
65 C20
Scott
Scott.
Looks good.
I'll take it.
P M sent.
Old 04-09-2014, 11:36 AM   #12
65 C20
Parts recieved.
Thanks Cal.
