12-29-2003, 11:59 PM | #1 |
HMMMM Chevy
Parting out a '68 Chevy swb 2wd
I am parting out the 68 Chevy I have. It is a short box, 2wd. body is surface rust mostly, no major holes. It was a 6 cyl/4spd. Now it's a v8/auto. There is no motor, that is for a project soon to come The trans is a 700r4, good running order. try to get pics soon.
68 Chevy C10 swb(under construction) 82 GMC K1500 6.2l diesel (daily driver) 77 Chevy K30 frame (only thing left is axles and trans/transfer)______________________________ Mike |
12-30-2003, 12:35 AM | #2 |
member
grille
What condition is the grille in, and how much is it worth to you?
Thanks John |
12-30-2003, 01:05 AM | #3 |
HMMMM Chevy
That would be one thing I forgot to mention the first time. The whole front clip is of the 70 vintage. Sorry about that.
12-30-2003, 01:11 AM | #4 |
HMMMM Chevy
While I'm at it, is is coil-over rear with 12 bolt. truck has been switched to 5 lug all around. Also the front was converted to disk brake. There is one other problem. The right front horn is cracked right under the motormount. The rear trailing arms are in excelent shape with polyurethane bushings.
12-30-2003, 01:30 AM | #5 |
Is the bed floor any good I need the right rear section with tail pan.
12-30-2003, 09:37 AM | #6 |
Chevy Freak
truck
How much for the whole truck? Thanks.
69 GMC SWB, 350 70 Chevy LWB, 350 55 chevy gasser, 461 73 Camaro, 496 67 RS Camaro, 406 64 Chevelle, 588 71 Nova, 565 67 Camaro, 461 |
12-30-2003, 11:42 AM | #7 |
Resident Curmudgeon
What is overall length of driveshaft? Pinion ujoint center to tranny?
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
