Old 03-15-2014, 05:58 PM   #1
Davewltn
Davewltn's Avatar
My son....
My 3 year old son just told me he he put a paper towl down into my gas tank.. He said he put black tape and a paper towl on a stick to see what was in there... . This is what happens when daddy goes to work. What do you all think? Will it dissolve or do I need to take my gas tank out and try to dump it and get it out...
Davewltn is offline   Reply With Quote
Old 03-15-2014, 06:19 PM   #2
Budman56
Budman56's Avatar
Re: My son....
pull it out and empty it that's probably not all that is in there. and its almost fifty years old it wont hurt it to be cleaned any way.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 03-15-2014, 06:39 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: My son....
You might find a matchbox car in there too...
You could pull the sending unit out and take a look from there. You may be able to fish it out from that hole.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-15-2014, 07:19 PM   #4
Davewltn
Davewltn's Avatar
Re: My son....
Thanks!! Should I drive it knowing that it's in there? I'm wondering if it will clog up and doesn't get gas to the engine...
Old 03-15-2014, 08:12 PM   #5
gimmy 64
Re: My son....
don't drive it or start it!!!!!!!!! pull the sending unit and see what you can. if you start it or run it you can have small bits of what ever in your fuel lines carb fuel pump --very costly!!!
gimmy 64 is offline   Reply With Quote
Old 03-15-2014, 08:21 PM   #6
oem4me
Re: My son....
Aww, aren't they precious ... I'd put some gas in a glass jar along with a paper towel and black tape and watch what is happening inside the tank. Some paper towels are like rags and others are like toilet paper. If you use the rag type, you might have luck snaring it with a hooked wire. ??
If the paper dissolves, I'd slap a cheap temporary inline filter on there before any muck gets in the carb, or you'll be pulling that too.
Good luck and go easy on the little fella.
Old 03-15-2014, 10:01 PM   #7
mud.man.rj
mud.man.rj's Avatar
Re: My son....
Now that is funny, cool he told you. Take the tank out or crap will make it's way to the carb eventually and then pulling the carb too.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 03-15-2014, 11:48 PM   #8
Davewltn
Davewltn's Avatar
Re: My son....
Thanks for the help! Yes my boy is funny.
Old 03-17-2014, 04:14 PM   #9
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: My son....
this will make for a good memory when he gets older...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-17-2014, 06:28 PM   #10
grs
Re: My son....
I had a 66 that had a new paint job. My son was about 5. He went into the garage and some how knocked a can of spray under coating on the floor. It sprayed all over the side of the truck. I never screamed at him because it was an accident.
grs is offline   Reply With Quote
Old 03-17-2014, 06:41 PM   #11
TJ's Chevy
TJ's Chevy's Avatar
Re: My son....
Pull the tank and dump the fuel in a 5 gallon bucket, and see if you can get that stuff out. The dump two cans of sea foam in along with a couple gallons of fresh gas and shake the tank real good so it'll clean it. After that, re-install with a locking gas cap. I'm sorry I have to admit this but...I blew up laughing when I read your story.
