Old 03-21-2014, 10:04 AM   #3
Captainfab
60-66 Nut
Re: 1965 k10 married sm465 np205 crossmember
It sounds like you are trying to put a different crossmember under the bellhousing as was in that '65 K10 originally. When upgrading to the newer married SM465/205 you will want to remove the original bellhousing crossmember and install a crossmember under the transfer case adapter as it was in the original application for that trans and transfer case combo.
