Old 03-21-2014, 09:25 PM   #1651
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by Xeen View Post
George it doesnt matter which way you do it the end result is the same.
Thanks , I tried to call you today. It keeps being busy. I guess you are a busy guy. I had a problem and I thought you could help. The bottom door hinge on the pass side where it bolts to the truck. Well, I got two bolts that will not tighten up. The nut behind the pillar is stripped. What is the best way to solve this problem? I don't want just one bolt holding the door up. Could I re tap to a larger size or weld it to the pillar. I really don't like the weld idea. You never know what the future will bring. I got the door adjusted right and hate to move it again. It took me about two hours doing it.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 03-21-2014, 09:27 PM   #1652
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by GEARBOXGARAGE View Post
The cowl will mount after the fenders as it covers the top 2 fender mounting bolts.
yea you are right I wasn't thinking when I posted. should I mount the cowl before the hood? Thanks Mike
Check out Patches
Old 03-21-2014, 09:34 PM   #1653
gdavis
gdavis's Avatar
Re: 1968
Today I finished the other door. It was a lot harder than the drivers side. I stripped two bolts on the bottom hinge. what to do now?????????????????? The truck looks like I stepped back a month or so. But I hope to have it all back together soon. I got to work out of the house tomorrow. So I don't think I will get a chance to do anything on the truck.
Both fender are off the truck and the grill. it looks bare bone now.
Check out Patches
Old 03-21-2014, 10:46 PM   #1654
Mustard72
Mustard72's Avatar
Re: 1968
Could you use a helicoil to recreate the original threads rather than tap to a bigger size? It gets a bit tricky with the captured nut, I suppose. I suppose either way you are removing the door again to drill out the holes. If the door is adjusted right at this point, though, you can drill a little hole through the hinge into the pillar and when it comes time to remount the door, use the drill bit as a dowel to line up the hinge to where you took it off from. I did that with Mustard after I got my doors lined up. Works like a charm. I can't claim credit for the idea, as I got it from Mr. Duckworth. I think I used a 1/16" or 3/32" drill bit for mine. One hole per hinge should do the trick.
....and now the rest of us will make sure to not overtighten our door bolts.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 03-21-2014, 11:23 PM   #1655
Xeen
Xeen's Avatar
Re: 1968
That's a bad place to have a stripped out bolt plate, ask Vic what he would do in this situation.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 03-22-2014, 05:34 PM   #1656
gdavis
gdavis's Avatar
Re: 1968
I did get to do something on the truck. I mounted the bed back on the truck. Here is the front picture of the truck after I pulled both fenders and grill. Maybe Monday I will get to re-mount the front clip.
It looks like I need to repaint the inter grill/radiator support. It has some orange over spray on it. I knew I had to pull the grill off. Now I see why. Vic gave me a idea about the hinge bolts. To step up to the next size and drill them out and tap them.
Check out Patches
Old 03-22-2014, 05:49 PM   #1657
gdavis
gdavis's Avatar
Re: 1968
yea those backing plate nut are old and don't and can't stand a I/2 drive socket and a strong arm.
Check out Patches
Old 03-22-2014, 10:40 PM   #1658
sduckworth13
sduckworth13's Avatar
Re: 1968
George here is a picture of what the plate of screws that sits behind the door pillar for the door bolts to go in.
Scott
sduckworth13 is offline   Reply With Quote
Old 03-22-2014, 10:42 PM   #1659
sduckworth13
Re: 1968
Here is one more
Scott
Old 03-23-2014, 09:07 AM   #1660
Xeen
Xeen's Avatar
Re: 1968
Vic said to try and use a M10x1.5 tap and the proper metric bolt and see if that works.
Old 03-23-2014, 08:12 PM   #1661
GEARBOXGARAGE
Re: 1968
That's what I did with mine and it worked perfect.
GEARBOXGARAGE is offline   Reply With Quote
Old 03-23-2014, 09:12 PM   #1662
gdavis
gdavis's Avatar
Re: 1968
Yea I know what it looks like. When I replaced the pillar on that side I removed it and put in another one that I thought was better. bad idea. Thanks Scott for posting the picture. I bet someone reading this post will thank you also. This place is a good place for information on these truck. And again thanks.
Check out Patches
Old 03-23-2014, 09:15 PM   #1663
gdavis
gdavis's Avatar
Re: 1968
I am going to try the tap that Vic said. I hope I have one. I have 100's of taps but want to take a bet that is one I don't have. anyway I will buy one if I don't.
George
Check out Patches
Old 03-23-2014, 09:21 PM   #1664
gdavis
gdavis's Avatar
Re: 1968
I did not work on my truck today. I worked with my Son-In-Law replacing the roof on his tool shed. It was in bad shape. it leaked and he did not think he was going to replace it. But he thought better when he priced a new shed. Sometimes age has it's advantages.
Check out Patches
Old 03-23-2014, 09:39 PM   #1665
1stchevy
1stchevy's Avatar
Re: 1968
Truck looks good, you'll be driving it in no time.
1stchevy is offline   Reply With Quote
Old 03-24-2014, 02:47 PM   #1666
GEARBOXGARAGE
Re: 1968
I like to mount the cowl and get the body lines matched to the doors and along the top of the fenders, then mount your hood and set the body lines/gaps to the cowl and top of fenders. Hope this helps.
Old 03-24-2014, 06:21 PM   #1667
gdavis
gdavis's Avatar
Re: 1968
Thanks for the information about the cowl. it helps.
Check out Patches
Old 03-24-2014, 06:23 PM   #1668
gdavis
gdavis's Avatar
Re: 1968
Yea I hope to drive it around the 1st of Aug.
need a complete exhaust
need a carb.
need front and rear bumpers for 67 thru 70 chrome.
wiring harness
as far as the truck I did nothing on it today.
Check out Patches
Old 03-24-2014, 10:32 PM   #1669
Dean'smeanmachine
Dean'smeanmachine's Avatar
Re: 1968
looks great!
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline   Reply With Quote
Old 03-25-2014, 07:17 PM   #1670
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by Dean'smeanmachine View Post
looks great!
Thanks a lot man.
Check out Patches
Old 03-25-2014, 07:27 PM   #1671
gdavis
gdavis's Avatar
Re: 1968
Today I bought a tap M10x1.50 for the stripped door hinge bolts. Guys it worked out real sweet. I went ahead and done all three bolts. That way they would be all the same on that hinge. There is a big difference in the hex size from American bolts. The old ones are 3/8 and the Metric is 17 MM. But who cares of that. All I know it worked and no damage to the truck.
I am hoping to paint the black of the truck tomorrow. I shot the orange and didn't cover the inter grill/rad core support as you can see in the picture. Then I will paint the hinges areas so that they will all look good.
Check out Patches
Old 03-26-2014, 10:27 AM   #1672
SeTx67
SeTx67's Avatar
Re: 1968
George, you've been knocking it out lately. Your truck is looking great and as usual you're moving right along
SeTx67 is offline   Reply With Quote
Old 03-26-2014, 10:45 PM   #1673
gdavis
gdavis's Avatar
Re: 1968
today I only worked on the vent doors and handles. Got them installed. I also put the e-brake handle mounted. Got a lazy streak. maybe tomorrow I will do some excited work I said maybe.
Check out Patches
Old 03-26-2014, 11:10 PM   #1674
Mustard72
Mustard72's Avatar
Re: 1968
Yeah, and maybe you'll have to mow the grass or some other March inFlorida type of thing....
Glad the door hinge issue worked out
Nick
Old 03-27-2014, 06:30 PM   #1675
gdavis
gdavis's Avatar
Re: 1968
Thanks, is it still cold up there in the yunkon
Check out Patches
